What's the best PC joystick?
Old June 5th 06, 07:04 AM posted to rec.aviation.simulators
Default What's the best PC joystick?
What is the best joystick for personal computer gaming?
Thank you.
Old June 5th 06, 01:18 PM posted to rec.aviation.simulators
On Mon, 05 Jun 2006 06:04:09 GMT, John Doe
postulated :
Can't say which joystick is the best but the best one I've owned and
operated is the Saitek X45.
Old June 5th 06, 02:40 PM posted to rec.aviation.simulators
* John Doe :
That depends on what games you think of. As you're posting to
rec.aviation.simulators I guess you're talking mostly of flight sims.
Thrustmaster Cougar HOTAS:
http://cougar.frugalsworld.com/
I do use it also with civil flight simulation. All the knobs give you
a real advantage in usability.
Things I have assigned to buttons for civil flight simming:
- extend flaps
- retract flaps
- extend/retract gear
- speed brakes / spoilers
- parking brake
- wheel brakes (have no pedals yet)
- differential wheel brakes left/right (- " -)
- reverse thrust
- COM1 transmit for ATC comms
- Autopilot disconnect
- Autothrust disconnect
- TO/GA thrust
- elevator trim up/down
- view direction
- zoom in/out
- choosing view position
- toggle kneeboard
- antenna elevation axis being used for rudder / nose wheel steering
And of course of you're into F-16 simming (Falcon 4.0 AF greeting), it's
THE stick+throttle system of your dreams (it's not perfect unmodified,
but comes close). :-)
Best regards,
Daniel
Old June 9th 06, 05:59 AM posted to rec.aviation.simulators
"John Doe" wrote in message
Thank you.
Old June 9th 06, 06:01 AM posted to rec.aviation.simulators
Thank you.
Old June 11th 06, 06:01 AM posted to rec.aviation.simulators
Beyondo?
info academieaviation.com wrote:
Path: newssvr14.news.prodigy.com!newsdbm05.news.prodigy. com!newsmst01b.news.prodigy.com!prodigy.com!newsco n02.news.prodigy.com!prodigy.net!nx01.iad01.newsho sting.com!newshosting.com!69.28.186.75.MISMATCH!hw mnpeer01.lga!hwmnpeer01.phx!news.highwinds-media.com!newsfeed1.easynews.com!easynews.com!easy news!atl-c04.usenetserver.com!news.usenetserver.com!wesley. videotron.net!wagner.videotron.net.POSTED!not-for-mail
Newsgroups: rec.aviation.simulators
References: Xns97D9ADCD18360123456789 207.115.17.102
Subject: What's the best PC joystick?
Lines: 8
X-Priority: 3
X-MSMail-Priority: Normal
X-Newsreader: Microsoft Outlook Express 6.00.2900.2869
X-RFC2646: Format=Flowed; Original
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2869
Message-ID: Jg7ig.10431$iO5.373925 wagner.videotron.net
Date: Fri, 9 Jun 2006 01:01:16 -0400
NNTP-Posting-Host: 69.70.245.83
X-Complaints-To: abuse videotron.ca
X-Trace: wagner.videotron.net 1149829289 69.70.245.83 (Fri, 09 Jun 2006 01:01:29 EDT)
NNTP-Posting-Date: Fri, 09 Jun 2006 01:01:29 EDT
Xref: prodigy.net rec.aviation.simulators:153790
"John Doe" jdoe usenetlove.invalid wrote in message
news:Xns97D9ADCD18360123456789 207.115.17.102...
Thank you.
Microsoft Flight Sim 4 - Looking For A Joystick Driver or Utility Rick F Simulators 2 April 8th 06 04:53 PM
Good joystick for MS FS2004? Andrei Dumitrescu Simulators 6 January 5th 05 05:43 AM
FS2004 and WinXP with Sidewinder Force Feedback joystick: can't control Apa Simulators 1 August 31st 04 09:23 PM
good combat flight sim, joystick questions Arjun Simulators 0 July 5th 04 02:58 AM
Joystick calibration problem with On Top 8.0 KC Jones Instrument Flight Rules 2 January 13th 04 05:06 AM
