Lowrance AirMap 2000c update
Old June 7th 06, 04:11 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Default Lowrance AirMap 2000c update
Stephen Farris wrote:
There's a software update for the Lowrance AirMap 2000c dated 5/26/06 on
the Lowrance website. It fixes the E6B/wind calculation problem, among
other things.
- Steve
I ran the update last night. Just for information, you don't have to
use your primary card that has the database to update the operating
software. That point may not be clear from reading the directions on
I connected the USB to SD card reader to my computer and inserted a new
SD card. From the Lowrance website, I downloaded the new V 1.6
software. It took up about 5.1 MB on the new card, although the
directions on the website said to make sure you have 2 MB available. I
opened the 2000c, removed the current database card, inserted the new
card, then powered the unit up. It loaded the new V 1.6 software and
came up in the non-Aviation mode, in Tulsa.
I powered the unit down, replaced the SD card with the original
database card. When I powered back up, the unit was running V 1.6, and
was back in aviation mode, again in Tulsa. Once it acquired, the unit
was back to displaying current location.
The whole process took a few minutes, with no surprises.
As long as I'm posting, I might as well include a PIREP. I bought the
2000c from Aircraft Spruce, price was $790 including shipping.
Lowrance was offering a trade-in for old units, so sent in my old
AirMap that has provided good service for the past 10 years. They gave
a $225 rebate after purchasing the 2000c, so my net price was $565.
Operation is similar to my old AirMap, so I was able to come up to
speed quickly. The unit also comes with a RAM mount, including a yoke
clamp for the plane and a windshield suction cup mount for the car.
Both work very well, and I didn't have to buy a single extra part.
Kudos for the well thought out mounting equipment. I think that the
mounts alone would cost an addtional $100 or so if bought separately.
There is only one negative so far. The dc power adapter (cigarette
lighter) works from 5v to 16v, or at least that is what is claimed in
the documentation. I have a 28 volt system in the plane. Interesting
that the adapter my 10 year old AirMap would work up to ~30 v or so. I
sent an inquiry to Lowrance customer support and got a legalistic
response that warranty would be void if operated outside of the stated
voltage ranges. Sometimes it seems that brand L is more comfortable
with fish finders than aviation products. It would be nice if I could
use my old adapter, but the plug at the unit is different - not a
standard that could easily be adapted. I have a dc/dc converter that
will convert 28v down to 12v. I'm going to to a bench test to plot V
out versus V in to see if the voltage regulator might work over an
extended range.
Display is fabulous, especially when upgrading from a 10 year old
monochrome display. The terrain awareness is awesome, and very useful
with a home airport in the Colorado front range (BJC - Jeffco). Street
prices are about half of comparable Garmin units - the 295 seems to be
around $1500. This isn't a slam of Garmin. I have friends with them
that are very happy. Based on experience so far, I can highly
recommend the 2000c.
Brian
Lowrance AirMap 2000c update Stephen Farris Owning 7 June 24th 06 06:46 PM
Lowrance AirMap 2000c update Stephen Farris Instrument Flight Rules 0 June 4th 06 03:24 AM
Lowrance 2000c update Stephen Farris Products 0 June 4th 06 03:18 AM
Looking for Calendar Year 2004 Lowrance Airmap 100 Database Update Ron Lee Piloting 2 August 16th 05 03:31 AM
Lowrance Airmap 2000c Jeremy Lew Piloting 3 May 18th 04 10:01 PM
