How much does an IO-540 weight, wet?
Old June 11th 06, 12:57 PM posted to rec.aviation.homebuilt
Default How much does an IO-540 weight, wet?
Anyone know the number?
Old June 11th 06, 01:54 PM posted to rec.aviation.homebuilt
http://www.lycoming.textron.com/main...Guide/540.html
"iliad" wrote in message
Old June 11th 06, 02:19 PM posted to rec.aviation.homebuilt
There's something like 70-80 versions of IO-540 existing. The FAA Type
Certificate Data Sheet No. 1E4 gives you the oil sump capacities and engine
version dry weights.
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/812be902103e2a7986256e700067f2f2/$FILE/1E4.pdf
JP
"iliad" wrote in
om...
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Dutch Roll SelwayKid Piloting 31 June 19th 04 11:43 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 07:32 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
