Altimeter inaccurate
Old May 2nd 04, 07:50 PM
smf
Default Altimeter inaccurate
My Altimeter is accurate when on the ground or at lower alt. When I climb up
to 7k and above and check it against GPS and approach controls read out it
is about 300+ feet off.
Is it the altimeter I'm having problems with?
Steve
Old May 2nd 04, 07:54 PM
Dan Luke
Probably not.
Your altimeter has no means to correct for non-standard temperature; GPS
altitude is unaffected by temperature.
Dan
C172RG at BFM
Old May 2nd 04, 08:15 PM
John R. Copeland
"smf" wrote in message =
news:jpblc.12364$bS1.6242@okepread02...
My Altimeter is accurate when on the ground or at lower alt. When I =
climb up
to 7k and above and check it against GPS and approach controls read =
out it
=20
=20
Steve
=20
It's possible you are not having any problems at all.
Barometric altimetry simply does not measure geometric height.
And most GPSs ignore barometric settings completely.
I'm unsure what you mean by "approach controls read out".
The controller can see only what your Mode C transponder sends.
Usually that reading is to the nearest 100 feet, and it derives from
a barometric sensor in your airplane, permanently set to 29.92 in.hg.
With a correct barometric setting, your altimeter should show the =
relevant
airport's elevation at its true height, but normally *not* any other =
elevation.
If your altimeter passes its 24-month 91.411 check, it's surely OK.
If it fails its check, though, you do have an altimeter problem.
---JRC---
Old May 2nd 04, 08:41 PM
Bob Gardner
AIM 1-1-20 (a)(8) tells us not to rely upon GPS to determine aircraft
altitude.
Bob Gardner
up
Steve
Old May 3rd 04, 03:40 AM
Judah
It begs an interesting question, though...
If an IAP is based on object clearance (in some cases, as low as 100'
clearance, right?), but does not account for temperature variations and
does not actually measure geometric altitude above the ground, is it not
possible that one would find oneself at an altitude that from a
barometric standpoint is legal and correct, but from a geometric altitude
is within the bounds of that tower that would have been 100' lower if it
also changed altitude with the temperature?
Just a thought...
"John R. Copeland" wrote in
climb up to 7k and above and check it against GPS and approach
controls read out it is about 300+ feet off.
Steve
relevant airport's elevation at its true height, but normally *not* any
other elevation. If your altimeter passes its 24-month 91.411 check,
it's surely OK. If it fails its check, though, you do have an altimeter
problem. ---JRC---
Old May 3rd 04, 04:24 AM
Teacherjh
IN theory yes, the altitude would be different from the indicated altitude.
However, you'd only be 100 feet away from the place where the altimiter setting
was derived, so the amount of error would be slight.
Jose
Old May 3rd 04, 05:39 AM
Andrew Sarangan
Temperature variations will cause an error but it is very small. The AIM
has a table that lists these errors. At 200' AGL (ILS minimum), you will
get a 20' error if the temperature is -20 C. It becomes 60' when the
temperature is -50C (not a common temperature in the US except may be
Alaska). The error is larger at higher altitudes (as much as 300' at 1000
AGL when the temperature is -50C).
Judah wrote in
and does not actually measure geometric altitude above the ground, is
it not possible that one would find oneself at an altitude that from a
altitude is within the bounds of that tower that would have been 100'
lower if it also changed altitude with the temperature?
Just a thought...
Steve
any other elevation. If your altimeter passes its 24-month 91.411
check, it's surely OK. If it fails its check, though, you do have an
altimeter problem. ---JRC---
Old May 3rd 04, 06:22 AM
John Bell
Just a thought...
And a good thought it is. Try this:
http://www.aircraftbuyer.com/learn/train06.htm
John Bell
www.cockpitgps.com
Old May 3rd 04, 12:55 PM
Ron Rosenfeld
It is my understanding that in Canada there is a requirement to alter
minimums for certain approaches in very cold weather. No such requirement
exists (Part 91, at least) in the US.
I don't believe there have been any accidents in the US due to this
phenomenon.
Old May 3rd 04, 09:34 PM
John R. Copeland
"Ron Rosenfeld" wrote in message =
=20
If an IAP is based on object clearance (in some cases, as low as 100' =
clearance, right?), but does not account for temperature variations =
and=20
does not actually measure geometric altitude above the ground, is it =
not=20
possible that one would find oneself at an altitude that from a=20
barometric standpoint is legal and correct, but from a geometric =
altitude=20
is within the bounds of that tower that would have been 100' lower if =
it=20
=20
minimums for certain approaches in very cold weather. No such =
requirement
=20
phenomenon.
=20
Along that line, perhaps you've noticed that the new VNAV approaches
typically carry a note to the effect that Baro-VNAV is not authorized
at temperatures below some limiting number.
---JRC---
encoding altimeter pinout? Bill Chernoff Home Built 3 July 15th 04 04:34 PM
Inaccurate airspeed indicator Wyatt Emmerich Instrument Flight Rules 20 April 20th 04 12:08 AM
Adjustment of Altimeter Ron Home Built 5 April 5th 04 03:12 AM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
Recommendation for Radio, transponder and Altimeter Ron Natalie Home Built 0 July 8th 03 03:40 PM
