Jepp vs NOS at PRB
Old May 5th 04, 03:58 AM
Doug Campbell
Default Jepp vs NOS at PRB
I was training with Jepp charts, and my partner (safety pilot) had NOS, and
we
were attempting the VOR DME (GPS) B approach into Paso Robles. The Jepp
chart shows the procedure turn (when starting at the VOR, not the arc)
starting
at 6 DME from the VOR, while the NOS chart shows it starting outside the 10
DME arc. Anyone know which is "right" or if it even matters? My instructor
didn't
know, and the DE for my checkride today (passed, by the way) said the NOS
was
probably "right" since it was much newer than the Jepp plate. But which is
ATC
expecting me to fly? DE said "fly what YOUR chart says (Jepp), but I'd like
a
more defendable answer.
Screwed it up anyway, as we talked about both the A and B VOR approaches,
and
I ended up with the A approach on the clip, but got cleared for B, so had to
recover
after the fact. Man, will I EVER stop making dumb mistakes?
TIA, Doug
Old May 5th 04, 11:45 AM
Ron Rosenfeld
On Tue, 4 May 2004 19:58:29 -0700, "Doug Campbell"
we
starting
didn't
was
ATC
a
and
recover
TIA, Doug
Well, I hate to say this, and I may be wrong (being a Jepp chart user), but
I think you, your instructor and the DE are all misinterpreting the NACO
chart.
Nowhere on the chart does it say to start the PT outside the 10 DME. As a
matter of fact, given the plan view restriction to remain within 10 miles
(of ILSIC), if you did not start the PT until the PRB 10 DME, you would
only have 3 miles in which to complete the PT!
The PT barb is shown where it's shown for charting convenience. But where
you start the turn is up to you, and you can start it any place after
ILSIC.
AIM 5-4-8 a.1. On U.S. Government charts, a barbed arrow indicates the
direction or side of the outbound course on which the procedure turn is
made. Headings are provided for course reversal using the 45 degree type
procedure turn.
**However, the point at which the turn may be commenced and the type and
rate of turn is left to the discretion of the pilot.**
(Emphasis mine)
Old May 5th 04, 12:22 PM
Mark Kolber
The Jepp
starting
I don't have the Jepp chart in front of me, but I'd bet that, not only
is Ron correct, but the bunch of you may be misinterpreting the Jepp
chart also.
Looking at the NACO chart
(http://naco.faa.gov/d-tpp/0404/00858VDGB.PDF) and starting from the
VOR, the full approach procedure it shows is to fly a course of 133°
at 5000 msl to ISLSIC (3 DME), the IAF (the only IAF on the chart that
requires a procedure turn. Note that the VOR is =not= an IAF).
Once crossing ILSIC, you may descend to 3600' and begin the procedure
turn - just keep it within 10 NM of ILSIC.
Once PT inbound, if you are more than 6 DME away from the VOR, you may
only continue your descent to 2400' until you reach the 6 DME point
(CFIVO) after which you may continue down to 2000' until ILSIC (the
FAF)
(Ron or other Jepp users, is this what the Jepp chart for the
procedure shows?)
Old May 5th 04, 12:44 PM
Ron Rosenfeld
On Wed, 05 May 2004 11:22:16 GMT, Mark Kolber
procedure shows?)
My Jepp service only covers the East so I can't comment on that approach
per Jepp.
But from the way the OP described it, it sounds as if they are making a
fairly common mistake of assuming that the location of the PT symbol on the
plan view has something to do with where you have to start the turn.
If it were one of those "fly as charted" type PT's, it would be a different
story.
I'm surprised that the DE didn't know better.
Old May 5th 04, 02:18 PM
Stan Prevost
"Ron Rosenfeld" wrote in message
but
chart.
ILSIC.
What you say is true, of course, Ron, but one does have to keep in mind that
the 3600 ft altitude restriction applies until PT completion and then 1600
ft must be lost getting back to ILSIC. That will take some distance, over 3
nm in a 90 kt spam can at 750 ft/min descent, so not beginning the PT until
past 6 DME (CFIVO) would be a good idea.
Stan
Old May 5th 04, 03:45 PM
Ron Rosenfeld
On Wed, 5 May 2004 08:18:48 -0500, "Stan Prevost"
but
chart.
ILSIC.
Stan
You're correct, and that gets into another issue of how best to fly that
approach. At 3NM and 90K GS one would need to descend 800 fpm. I'd
probably perform a teardrop PT on this approach, and go out far enough to
have a comfortable descent rate, given the winds.
Old May 5th 04, 04:23 PM
Greg Esres
I'm not. Exactly what resources exist which could relieve him of this
misconception once he has acquired it? Zippo.
Old May 5th 04, 05:01 PM
Dave Butler
As I read the post, the examiner just told him to do what was published on the
chart. There's nothing to indicate what the examiner did or did not know.
Dave
Remove SHIRT to reply directly.
Old May 5th 04, 05:38 PM
Ron Rosenfeld
On Wed, 05 May 2004 12:01:46 -0400, Dave Butler
Dave
I read the post differently, Dave.
It seemed to me that the OP was asking the DE about whether Jepp or NACO
was "correct" in view of the difference in the way the PT was charted on
the Plan View. And the DE responded that probably the NACO chart was
correct.
Although I don't have the Jepp chart at hand, it seems to me that both
charts are likely correct, with the PT charted in a different place on the
plan view.
The DE saying that the NACO chart was probably correct means he either
didn't understand the question, or was agreeing that the difference in
location of the PT on the plan view was meaningful.
Old May 5th 04, 05:40 PM
Ron Rosenfeld
The AIM, for one.
Airport Radial/Distance/Fix on Jepp Airport Chart Dave Johnson Instrument Flight Rules 9 May 2nd 04 11:03 PM
JEPP Chart Users Ross Richardson Instrument Flight Rules 6 March 29th 04 10:58 PM
who moved SAV, forgot to tell Jepp? Dave Butler Instrument Flight Rules 15 November 9th 03 02:16 AM
Jepp Charts - Subscription Only? Peter Gibbons Instrument Flight Rules 8 November 8th 03 02:01 PM
req: a favor from someone who subscribes to Jepp for Hawaii [email protected] Instrument Flight Rules 2 October 22nd 03 07:24 PM
