I'm trying to improve my database generators for CoPilot and other
programs (see http://navaid.com/ and http://xcski.com/~ptomblin/CoPilot/ for details). The problem I'm trying to deal with is that the FAA is totally inconsistent on how they name waypoints, DAFIF isn't any better, and there are literally thousands of them. And because of that, I am having real problems giving people a way to select just the types of waypoints they want. I look through my databases and find instances of what I would consider en-route waypoints labelled "WAYPOINT", "REP-PT", even "RNAV-WP". One guy suggested that I just give the option of only selecting waypoints if they are 5 alphabetic characters, with no numbers. The problem I have with that is that I still end up with a lot of IAP waypoints, including GPS ones, which bloats the database. Now I don't know about you, but I don't put in the waypoints for an instrument approach when I flight plan - I generally put the departure airport, the first fix on the filed route, then I find the last waypoint on the en-route chart that would apply to the STAR or normal approach, put that in and the airport, and then apply a fudge factor for how long a departure procedure and approach should take. Do other people do any differently? Are you likely to want every named step-down fix and GPS fly-over waypoint on your flight planning tool? Another possibility I was looking at was that the FAA waypoint file lists what charts a waypoint appears on, and DAFIF categorizes their waypoints as "HI", "LOW", "BOTH", "RNAV" or "TERMINAL". So I was thinking maybe of categorizing waypoints that way and allowing people to pick any combination of: - points that appear on High Altitude En-Route charts - points that appear on Low Altitude En-Route charts - points that appear Instrument Approaches ("Terminal") The only problem I have is with SIDS (sorry, DPs) and STARS - should they be classified as "terminal" or as "en-route"? -- Paul Tomblin http://xcski.com/blogs/pt/ The problem with this country is that half of the population is below median intelligence |
(Paul Tomblin) wrote in
: I'm trying to improve my database generators for CoPilot and other programs (see http://navaid.com/ and http://xcski.com/~ptomblin/CoPilot/ for details). The problem I'm trying to deal with is that the FAA is totally inconsistent on how they name waypoints, DAFIF isn't any better, and there are literally thousands of them. And because of that, I am having real problems giving people a way to select just the types of waypoints they want. I don't have a solution, Paul, but if you do find a solution let me know. I don't use any of these very often, because I rarely fly on airways, but it would be nice to be able to easily get what I do need. I have room on my SD card for lots of waypoints, but the more you have, the longer sorting and searching takes. -- Regards, Stan |
(Paul Tomblin) wrote: [snip] Are you likely to want every named step-down fix and GPS fly-over waypoint on your flight planning tool? If you are referring to points in approaches, then no, I wouldn't want them. Do you know what the DAFIF/Arinc 424 rules are for naming points? Might that help a little? -- Bob Noel |
In a previous article, Bob Noel said:
Do you know what the DAFIF/Arinc 424 rules are for naming points? Might that help a little? The DAFIF WPT.TXT file only uses a few type classfications, "I" (Unnamed, charted or computer nav fix), "IF" (same, but off-route), "R" (named fix), "RF" (named, off-route), "NR" (named NDB fix), "NF" (off-route NDB fix) and "V" (vfr reporting point). Not terribly helpful since "R" "named fix" doesn't distinguish between en-route and approach named waypoints. And they don't see very consistent. That's why I'm looking to combine that Type field with the Usage Code field. -- Paul Tomblin http://xcski.com/blogs/pt/ Died. Woke up in Hell. Punched in PIN, logged on. Just another day. -- David Gerard |
![]() "Paul Tomblin" wrote in message ... I'm trying to improve my database generators for CoPilot and other programs (see http://navaid.com/ and http://xcski.com/~ptomblin/CoPilot/ for details). The problem I'm trying to deal with is that the FAA is totally inconsistent on how they name waypoints, DAFIF isn't any better, and there are literally thousands of them. And because of that, I am having real problems giving people a way to select just the types of waypoints they want. I look through my databases and find instances of what I would consider en-route waypoints labelled "WAYPOINT", "REP-PT", even "RNAV-WP". One guy suggested that I just give the option of only selecting waypoints if they are 5 alphabetic characters, with no numbers. The problem I have with that is that I still end up with a lot of IAP waypoints, including GPS ones, which bloats the database. Now I don't know about you, but I don't put in the waypoints for an instrument approach when I flight plan - I generally put the departure airport, the first fix on the filed route, then I find the last waypoint on the en-route chart that would apply to the STAR or normal approach, put that in and the airport, and then apply a fudge factor for how long a departure procedure and approach should take. Do other people do any differently? Are you likely to want every named step-down fix and GPS fly-over waypoint on your flight planning tool? Another possibility I was looking at was that the FAA waypoint file lists what charts a waypoint appears on, and DAFIF categorizes their waypoints as "HI", "LOW", "BOTH", "RNAV" or "TERMINAL". So I was thinking maybe of categorizing waypoints that way and allowing people to pick any combination of: - points that appear on High Altitude En-Route charts - points that appear on Low Altitude En-Route charts - points that appear Instrument Approaches ("Terminal") The only problem I have is with SIDS (sorry, DPs) and STARS - should they be classified as "terminal" or as "en-route"? This would be great for me, because I often use the waypoints to georeference approach charts and enroute charts, (e.g. see alt.binaries.pictures.aviation "TPL GPS 33"). I remember once before having trouble that you're talking about, with the categorization WAYPOINT", "REP-PT", "RNAV-WP", etc. Thanks a lot for your service! Cheers, John Clonts Temple, Texas N7NZ |
As a rule I don't download any of the waypoints for CoPilot. I
manually enter the handful I need for VFR (already on the computer in a file so I can download easily if they ever disappear). If I go someplace where I need more, it's usually just a few, so those can be manually loaded too. |
![]() Paul Tomblin wrote: I'm trying to improve my database generators for CoPilot and other programs (see http://navaid.com/ and http://xcski.com/~ptomblin/CoPilot/ for details). The problem I'm trying to deal with is that the FAA is totally inconsistent on how they name waypoints, DAFIF isn't any better, and there are literally thousands of them. And because of that, I am having real problems giving people a way to select just the types of waypoints they want. I look through my databases and find instances of what I would consider en-route waypoints labelled "WAYPOINT", "REP-PT", even "RNAV-WP". One guy suggested that I just give the option of only selecting waypoints if they are 5 alphabetic characters, with no numbers. The problem I have with that is that I still end up with a lot of IAP waypoints, including GPS ones, which bloats the database. In NACO's DAI CD-ROM those fixes are segregated by: DPs, IAPs, STARs, en route low, and en route high. Seems using the en route low file would solve your problem. |
Planning on RV10 | MR | Home Built | 4 | December 28th 04 02:51 AM |
Want simple flight planning software | marc | Home Built | 13 | December 20th 04 04:36 AM |
Route planning question | Paul Tomblin | Instrument Flight Rules | 3 | April 4th 04 02:40 PM |
Global Aviation Flight Planning Software – Free | Greg Siemon | Instrument Flight Rules | 0 | December 20th 03 05:42 PM |
Flight Planning software | PA28Rdrvr | Instrument Flight Rules | 6 | August 12th 03 12:18 AM |
