I was looking at Phoenix AZ on the low altitude en-route chart, and there
is a cluster of GPS waypoints charted all around the VOR (in the Class B). I assume those are for GPS instrument approaches. Is there a reason why those are charted on the en-route? -- Paul Tomblin http://xcski.com/blogs/pt/ I think I'd like to see a Simpsons episode starting up with Bart Simpson writing 'I will not attempt to undermine the Usenet Cabal'. -- J. D. Falk |
![]() Paul Tomblin wrote: I was looking at Phoenix AZ on the low altitude en-route chart, and there is a cluster of GPS waypoints charted all around the VOR (in the Class B). I assume those are for GPS instrument approaches. Is there a reason why those are charted on the en-route? Those are waypoints on RNAV SIDs out of KPHX. The FAA and the airlines are having a lot of problems getting those RNAV SIDs (aka: ATC DPs) to work smoothly. It was thought by someone that including the fixes on the en route chart would help. But, who knows? |
![]() Roy Smith wrote: In article , wrote: The FAA and the airlines are having a lot of problems getting those RNAV SIDs (aka: ATC DPs) to work smoothly. What does it mean for a SID not to work smoothly? They have had a whole lot of problems, particularly at PHX and LAS. The various aircraft have RNAV avionics that handle the critical waypoints and tracks differently. Also, even the positions are different for air carrier aircraft with GPS and the older "glass cockpit" airliners that use DME/DME updating. There were periods where the FAA suspended use of the procedures because of controller complaints. That, in turn, resulted in the airlines whining to no end. It got so bad the FAA belatedly issued an air traffic bulletin to controllers covering the subject to some extent: http://www.faa.gov/atpubs/atbarc/03-5.htm |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
Grandmother Goes Down at the Pole | BJ | Home Built | 66 | January 13th 04 04:10 PM |
How fast should an ADF point? | Ben Jackson | Instrument Flight Rules | 6 | November 21st 03 03:50 AM |
Reaming needed on aft wing attach point. | Boelkowj | Home Built | 0 | November 7th 03 01:30 AM |
Surface radiators for water cooled engines | Harry Burns | Home Built | 65 | July 22nd 03 05:45 PM |
