Thermal Lift Dynamics
Old June 18th 06, 01:46 AM posted to rec.aviation.soaring
Default Thermal Lift Dynamics
I've been flying my 12m Silent-IN all by mysel up in Northern Maine.
I'm finding conditions are usually marginal. 5kts is the best I've
ever seen on the very best day. Typically I see 2-3kts and real
scratchy at that.
I often run into a kind of lift (particullarly up near the cloud decks)
where the lifts comes on gradually, then crashendo's and crashes behind
it. It doesn't feel like a typical thermal. It feels more like some
kind of mechanical turbulance or a sheer wall.
In other regions I've flown (Eastern Washington State) lift blew the
caps off vario and it wanted to shooved you right through bottom of the
cloud. Here (Northern Maine) it's just so weak I can barely make it to
the decks, then this "sheer lift" forms and I can't stay in lift long
enough to make good progress.
A plausable technical description of what I've observed would really
help me visualize the phenom and maybe fly it better.
Bruce Meacham
Old June 20th 06, 10:48 AM posted to rec.aviation.soaring
Are you sure you are circling tight enough? It may be that the thermal
cores are very narrow, and you are not getting into them. You may have
experienced larger thermals out west, and could circle in them without
banking that much.
Try making a small right angle bend out of solid wire, and mount it up
on the panel so it shows a 45 degree angle like a letter-v (you may
have seen something similar on an aerobatic airplane). Use it as a
reference with the horizon to see if you really are banking at 45
degrees in a tight thermal. You may be surprised to learn that what you
thought was 45 degrees was only 30 or so. It's a very common problem.
Other things to check are your vario TE compensation, and tubing leaks.
It may also be instructive to carry a logger and analyze the flight
traces with a flight ananlysis program like SeeYou or StrePla.
scratchy at that.
Bruce Meacham
Old June 20th 06, 11:04 AM posted to rec.aviation.soaring
"Doug Haluza" wrote in message
In a glider with a reasonably supine seating position I use the instrument
mounting screws as a 45 degree reference. It's not so easy to do in a glider
where you're sitting up more because the instruments aren't so near the
horizon.
Stephen
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
New theory of flight released Sept 2004 Mark Oliver Piloting 70 October 10th 04 10:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
