NDB or GPS Rwy 33 EPM
Old May 19th 04, 07:53 PM
Ron Rosenfeld
Default NDB or GPS Rwy 33 EPM
This approach is marked radar required, and there is no charted feeder
route to the IAF. So one approaches via a random route under radar.
ATC will not issue an approach clearance until within 15 miles of the NDB.
In the past I was told this was due to their need to ensure the a/c was
within the service volume for the facility.
However, if the a/c is using GPS and executing the GPS Rwy 33 approach,
what is the point of delaying clearance issuance until 15 miles out?
Old May 20th 04, 01:35 PM
Ron Rosenfeld wrote:
On Thu, 20 May 2004 02:38:59 GMT, "Steven P. McNicoll"
"Ron Rosenfeld" wrote in message
One reason for delaying the clearance when using the NDB might
be that, although ATC may be radar monitoring, once one
descends below 4000', there is no direct radio contact with ATC.
Radar monitoring is required even if the aircraft is executing the GPS RWY
33 approach.
Why do you think this delay in issuing the clearance is a policy at the
Boston ARTCC?
If it is not justified by the FAA published procedures, do you have a cite
from the manual that I could present to the supervisor at the Boston ARTCC
to support its elimination?
"RADAR REQUIRED" can be for any number of reasons. One of them is:
8260.19C, Para 855: Where radar is the only method for procedure entry from
the en route environment, enter the following: Chart planview note: RADAR
REQUIRED.
You cannot use that NDB beyond 15 miles unless they see you on radar. You say
they lose radar below 4,000, but presumably you're within 15 miles before they
let that happen. The note is appropriate in view of the lack of facilities
supporting the IAP. It is not Boston Center that is the final authority on
that note, it is the IAP folks.
The fact you're using GPS is beside the point because it is an overlay IAP.
Perhaps it shouldn't be beside the point, but it is because it's an overlay.
They don't make special notes for overlay use of a ground-based IAP.
Old May 20th 04, 05:25 PM
No, they don't lose radar -- but they do lose direct radio communications.
Communication is still possible, although cumbersome, through a FSS.
If they can't talk to you they can't provide radar services. ;-)
Old May 20th 04, 06:22 PM
Steven P. McNicoll
Boston ARTCC?
I don't think there is a delay. If you're on a random route radar
monitoring is required for all aircraft; course guidance is also required,
as necessary, unless the aircraft is /E, /F, /G, or /R equipped.
(Apparently non-advanced RNAV aircraft must be nudged back on course but
advanced RNAV aircraft can be left to wander.) Implicit in the requirement
for radar monitoring is the requirement for direct pilot-controller
communications. If radio communication is lost below 4000' then any
clearance that permits descent below that altitude must be withheld until
the requirement for radar monitoring no longer applies. If you really want
your approach clearance before you're within 15 miles of EPM ATC can easily
issue it with a restriction to maintain 4000' until crossing EPM NDB, but I
doubt that's a solution you'd be interested in.
Another solution is to file a route that does not require radar monitoring
as you approach EPM, but that may require you to add a fair distance to your
flight. Princeton VOR/DME is an L class VOR 39 miles NNW of EPM, the A/FD
shows no restrictions within the normal altitude/distance limitations, so
PNN direct EPM is a perfectly good non-radar route. You could be cleared
for the approach with a restriction to cross EPM at whatever the highest MIA
is between the VOR and the NDB. Radar monitoring wouldn't be required so
there'd be no reason to keep you on the ATC frequency or deny the approach
clearance.
One wonders why this wasn't charted as a feeder route.
Old May 20th 04, 06:59 PM
Steven P. McNicoll
wrote in message ...
of them is:
procedure entry from the en route environment, enter the
following: Chart planview note: RADAR REQUIRED.
Radar is not the only method for procedure entry from the en route
environment in this case.
on radar.
That's true, but you could use another navaid until you're within 15 miles
of that NDB.
You say they lose radar below 4,000, but presumably you're
within 15 miles before they let that happen.
He didn't say that, he said they lose direct communications below 4000'.
The Bucks Harbor ARSR is only 23 miles away, the St. Albans RCAG is about
100 miles away.
supporting the IAP.
The note is inappropriate in view of the fact that this procedure can be
flown without the use of any radar services.
Old May 20th 04, 09:12 PM
Ron Rosenfeld
On Thu, 20 May 2004 17:22:30 GMT, "Steven P. McNicoll"
Boston ARTCC?
Sometimes it's hard for me to follow your train of thought. But if I
understand you correctly, in the situation we are discussing, you are
saying that for a/c with non-advanced RNAV, clearance issuance *should* be
delayed until within the SSV of the EPM NDB (unless one is held at an
excessively high altitude).
However, I was filed /G so I'm still wondering about my specific situation.
clearance.
I don't have a current AF/D to examine. However, the Princeton VOR has
been flakey for a number of years. In addition, www.airnav.com shows VOR
PORTION UNUSBL 113-158 (pnn--epm is 149°). Also, checking with the Bangor
FSS, they tell me that restriction is published in the current A/FD.
(I believe that many years ago there was a published feeder route.)
So I guess that's not an option.
Oh well.
I'll see what the local procedure specialist has to say.
Old May 20th 04, 09:15 PM
of them is:
What are the other methods?
Old May 20th 04, 09:17 PM
Perhaps flight inspection issues?
Old May 21st 04, 03:29 AM
J Haggerty
Unless the NDB is part of the airway system, then Radar is the only way
to legally and procedurally get to the IAF.
on radar.
miles
of that NDB.
There are no other NAVAIDS that have been approved as feeders to the
IAF. Yes, you could use another NAVAID to get there, but it would have
to be with the assistance of the TRACON while they follow you on the
Radar (i.e., Radar required)
100 miles away.
supporting the IAP.
Not from a TERPS standpoint.
JPH
