If you float in above the threshold a fair bit higher than Vref, is it
acceptable technique to chance the reverser to preclude landing too far down the runway? Thanks in advance, Ramapriya |
No
Vref is 1.3 Vso and even at higher speed float is not a real problem, you fly the pitch attitude to a firm landing and deploy the spoilers. Most jet aircraft have a nose down, negative wing angle when the nose wheel is on the surface. You can "plant" a jet and keep it on the ground without the problem of ballooning off the ground that most light aircraft encounter. If you are out of the proper position, the proper procedure is a go-around. BTW, it seems you are trying to learn about paining aircraft (decoy) and how to "speak" pilot, is there any ulterior motive such as passing a security check with a stolen airplane painted away from a professional shop and flown by a crew that isn't qualified? wrote in message oups.com... | If you float in above the threshold a fair bit higher than Vref, is it | acceptable technique to chance the reverser to preclude landing too far | down the runway? | | Thanks in advance, | | Ramapriya | |
wrote in message oups.com... If you float in above the threshold a fair bit higher than Vref, is it acceptable technique to chance the reverser to preclude landing too far down the runway? Thanks in advance, Ramapriya I just open the door and throw out the anchor. Works best on soft grass runways. |
Dave Stadt wrote:
wrote in message oups.com... If you float in above the threshold a fair bit higher than Vref, is it acceptable technique to chance the reverser to preclude landing too far down the runway? Thanks in advance, Ramapriya I just open the door and throw out the anchor. Works best on soft grass runways. That is called a soft-field landing, right? You should use it on all grass strips, not just the soft ones. Because you never know when one may be soft, so just assume that and always use the anchor. Worst case is that the grass runway is hard and it just bounces along behind you. No hard as long as it doesn't wrap around the tail. :-) |
wrote in message If you float in above the threshold a fair bit higher than Vref, is it acceptable technique to chance the reverser to preclude landing too far down the runway? It is bad technique to "chance" anything. Jim is right in that if you're out of position for landing a miss should be your first consideration. I can't speak for all transports, but I seem to recall on the 727 and 747 there are lockouts that prevent reverse actuation in flight. Not 100% sure of the physical lockout on the 727, and too lazy right now to look it up. :-) I do recall that inflight reverser use was possible on at least some models of the DC8. In any event, I wouldn't consider use of reverse immediately before landing a good idea. |
I don't know what color your skin is and don't really care
about your skin. But I was raising the issue since you have asked questions about many subjects and topics that could fit a profile of a person wanting to bad things. The answers to those questions can be harmless as can the questions. Yes, 9/11 has changed the way pilots are seen and the way pilots look at others. We used to be a sort of "band of brothers" and now we have to wear a name badge, neckstraps with ID cards, and have the color of the day on the lapel. I'm pretty sure that the newsgroups are monitored and I was just pointing out that the pattern of your questions could come to the attention of some agency. No offense was intended. Jim wrote in message oups.com... | Jim Macklin wrote: | | | BTW, it seems you are trying to learn about paining aircraft (decoy) and how to "speak" | pilot, is there any ulterior motive such as passing a security check with a stolen | airplane painted away from a professional shop and flown by a crew that isn't qualified? | | | No way! | | It seems like post 9/11, to even want to know about aviation isn't the | done thing, and certainly not if you've dark skin. Unfortunate... but I | don't hold out against you, Jim. I've had worse insinuations here on | RAP in the past for no reason at all. | | Ramapriya | |
wrote in message ... On 24 Jun 2006 03:48:13 -0700, wrote: having the buckets out while flying is a RBT (really bad thing), but I'm sure there are some exceptions out there. http://www.globalsecurity.org/milita...craft/c-17.htm TC Yup, you found it. The C-17 thrust reversers are certified as flight controls. |
The props on the King Air will reverse in-flight as can the
Pilatus bushplane. There can be some interesting aerodynamic effects. But very few recreational airplanes have any sort of reverse. But I agree, jets require the squat switch (unless there is a malfunction) to deploy reverse. -- James H. Macklin ATP,CFI,A&P wrote in message ... | On 24 Jun 2006 03:48:13 -0700, wrote: | | If you float in above the threshold a fair bit higher than Vref, is it | acceptable technique to chance the reverser to preclude landing too far | down the runway? | | I've only allegedly worked on couple of different types of buckets, | all on biz-jets and they have had one thing in common. | | The aircraft must have a weight-on-wheels signal present somewhere in | the logic circuit before the reversers will unlock or deploy. | | Inflight, if a not-locked condition is detected, the reversers are | hydraulically driven to the stowed position and pressure is maintained | holding them there until the not-locked condition goes away. | | Unless you are learning to fly the space shuttle: | | http://www.nasa.gov/vision/space/pre...week5_sta.html | | http://www.nasaexplores.com/show2_ar....php?id=04-067 | | http://www.aopa.org/pilot/features/9703feat.html | | having the buckets out while flying is a RBT (really bad thing), but | I'm sure there are some exceptions out there. | | http://www.globalsecurity.org/milita...craft/c-17.htm | | TC |
John Gaquin wrote:
I can't speak for all transports, but I seem to recall on the 727 and 747 there are lockouts that prevent reverse actuation in flight. Not 100% sure of the physical lockout on the 727, and too lazy right now to look it up. :-) I do recall that inflight reverser use was possible on at least some models of the DC8. John, I'm sure the Thailand Air Lauda A320 crash of about 10 years ago has escaped your attention ![]() The pilots somehow accidentally deployed the reversers on finals and couldn't recover the craft ![]() Ramapriya |
| Thread Tools | |
| Display Modes | |
| Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 10:32 PM |
| Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 04:07 PM |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Partnership Question | Harry Gordon | Owning | 4 | August 17th 03 12:23 AM |
