Dropped Spark-Plug Consequences?
Old June 27th 06, 12:35 AM posted to rec.aviation.owning
Default Dropped Spark-Plug Consequences?
Could having dropped a spark-plug (REM38E in a Lyc O-360-A2D) cause
static in the radio when on one mag with none on the other mag? What
other consequences might there be from a dropped plug? I've been
wrestling with a static-noise problem on one mag in the radio. I got
some
good advice here previously, but just remembered that I did drop a plug
on the floor and put it back. Don't know if this is when the problem
started or not. Can't remember. Thanks.
Old June 27th 06, 01:12 AM posted to rec.aviation.owning
"Kensandyeggo" wrote in message
some
Dropped plug (on a hard surface like metal, asphalt or concrete) means "drop
it one more time... into the trash". It is easy to crack the ceramic
insulator, initiating arc paths at places other than the tip. The loose
insulator may separate completely, causing ceramic or metal parts to be
tossed into the operating engine and/or causing a high temperature gas leak.
I could go on and on. Yes, the radio noise could be caused by a bad plug.
Bite the bullet and put in a new plug, even if it does not fix the noise
problem in the radio.
Just my 2cents,
John Severyn @KLVK
Old June 27th 06, 01:43 AM posted to rec.aviation.owning
some
Just my 2cents,
John Severyn @KLVK
I did order a new one, John. I'll see what it does when I get it.
Ken
Old June 27th 06, 01:46 AM posted to rec.aviation.owning
Yes. It may also intermitantly fail. I had one dropped and I would see
it fail every once in a while in flight. On the ground it always seemed
to run. Replaced it with the spare (ALWAYS keep a spare sprark plug and
wrench in the back of your plane) and never had the problem again.
-Robert
some
Consequences of dropped spark-plug? Kensandyeggo Home Built 4 June 27th 06 02:13 AM
Spark plug question for Archie John S Home Built 0 February 17th 05 06:56 PM
Spark plug question: Massive electrode or fine wire? Peter R. Owning 9 February 4th 05 02:03 AM
Vintage spark plug Robert Eagle Restoration 0 November 30th 04 08:57 PM
Pilot/Owner Signoff for spark plug maintenance? John Clonts Owning 3 September 14th 04 11:08 AM
