Dyneema Cable
Old June 27th 06, 03:02 PM posted to rec.aviation.soaring
Default Dyneema Cable
We have been using 1 Dyneema cable @ Bowland Forrest
for the
past 12 Months - on grass with rubble hardned tow out
track
After initial teathing troubles - Finding the most
durable cable
manufacturer and modifying linkages and shock ropes
etc it has
now settled down and we have converted both drums to
Dyneema.
The cable lifts free of the ground as soon as tension
is put on it
therefore wear and tear on the ground is minimal either
at cable
retrieve or launch
Launch hight are regularly 200ft higher than stranded
steel cable
and there are significantly less cable breaks.
Care has to be taken not to land across thc line of
cables as the
cable can stand above the surface of the grass especially
in dips
or hollows or when the cable is under any kind of
load - ie cable
retrieve - hand pulling of cable to obtain slack to
attach to a
glider etc. (This is potentially far more hazardous
than steel
which tends to bed into the grass.
Also worth noting is the potential for the cable to
fly in windy
conditions - so care must be taken on the retrieve
to make sure
cables do not cross and that a very large seperation
is used @
the departure point.
Old June 27th 06, 04:36 PM posted to rec.aviation.soaring
Interesting comments about the rope resting on the grass and the snag
hazards.
What is the length of your launch run?
Frank Whiteley
for the
track
durable cable
etc it has
Dyneema.
is put on it
at cable
retrieve or launch
steel cable
cables as the
in dips
load - ie cable
attach to a
than steel
fly in windy
to make sure
is used @
Old June 27th 06, 10:21 PM posted to rec.aviation.soaring
is put on it
at cable
retrieve or launch
Out of curiosity, have you tried any lowish level simulated power
failures with it? My own observation is that during a power fail the
weight of steel cable keeps the drogue and shock cord well out of the
way below the glider, but I've wondered what happens with Dyneema.
The possibility of it not being heavy enough to keep the drogue etc.
clear of the glider is my only worry about taking a launch on it.
I don't remember this point being discussed here.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 28th 06, 02:50 AM posted to rec.aviation.soaring
is put on it
at cable
retrieve or launch
I've posted here and on the winchdesign group about the 'float' we
experienced. However, we also used our normal chute and strop
arrangement. Powered off, the strop falls first, causing the chute to
collapse and the rig falls out of the way taking the rope with it. The
remaining rope did fall rather slowly, but it would take, in my
estimation, quite an effort to get under it.
That being said, the new plastic disk design and other light weight
solutions might lead to longer hang times for the rope in the event of
the launch failure.
Frank Whiteley
Old June 28th 06, 05:41 PM posted to rec.aviation.soaring
durable cable
etc it has
Which cable worked (diameter, construction and supplier), and which did
not?
The cable lifts free of the ground as soon as tension is put on it
therefore wear and tear on the ground is minimal either at cable
retrieve or launch
What is the vertical curvature of your field - is there a convex shape
which assists in holding the cable off the ground during tow back?
Also worth noting is the potential for the cable to fly in windy
conditions - so care must be taken on the retrieve to make sure cables
do not cross and that a very large seperation is used @ the departure
point.
What chute, strop and weak link arrangement are you using? What mods did
you do to the winch (guillotine etc).
Anybody else been down this road who can provide feedback? We have a
winch which need new cables and I am trying to collect as much information
as possible so that we can make good decisions.
Thanks
Ian
PIREP: Garmin GMA340 impedance-matching audio cable Peter R. Owning 5 June 15th 06 02:30 PM
nicopress sleeve for stainless steel cable ls Home Built 3 December 6th 05 04:09 PM
Helicopter knocks out cable car, killing nine. Flyingmonk Piloting 12 September 16th 05 12:27 AM
Stuck cowl flap cable Jim Burns Owning 7 March 24th 05 02:07 PM
Winch cable Bill Daniels Soaring 5 August 24th 03 11:13 PM
