Hi all,
Question: take a look at the VOR Rwy 28 approach at Marshall Brooks field (RMY). I've filed IFR to airports where the VOR IAF happened to be the VOR which was no problem, I'd just have that VOR be the last fix in the route box on flight plan form. In RMY's case, the IAF appears to be the intersection ALBIO. So, on the flight plan, should the route terminate at ALBIO? That intersection isn't even on the enroute chart. Thanks. P.S. Sorry haven't posted in a while, have had no time to read or post. ![]() - Slav |
![]() "Slav Inger" wrote in message om... Question: take a look at the VOR Rwy 28 approach at Marshall Brooks field (RMY). I've filed IFR to airports where the VOR IAF happened to be the VOR which was no problem, I'd just have that VOR be the last fix in the route box on flight plan form. In RMY's case, the IAF appears to be the intersection ALBIO. So, on the flight plan, should the route terminate at ALBIO? That intersection isn't even on the enroute chart. Thanks. If the fix isn't on the enroute chart it likely isn't stored in the flight data processing computer. Filing such a fix in a route will cause the flight plan to terminate at the previous known fix or be rejected completely. Just file from the last enroute fix that is on the chart direct to the field. It's just not that critical. |
Your clearance will be to the destination airport, so why no make that the
last entry in the route? Bob Gardner "Slav Inger" wrote in message om... Hi all, Question: take a look at the VOR Rwy 28 approach at Marshall Brooks field (RMY). I've filed IFR to airports where the VOR IAF happened to be the VOR which was no problem, I'd just have that VOR be the last fix in the route box on flight plan form. In RMY's case, the IAF appears to be the intersection ALBIO. So, on the flight plan, should the route terminate at ALBIO? That intersection isn't even on the enroute chart. Thanks. P.S. Sorry haven't posted in a while, have had no time to read or post. ![]() - Slav |
Hey Slav, how are ya.
My CFII's IR notes have a bold entry for "Always file to an IAF" and that's what I do. Not saying this is correct or not, hopefully this thread sorts it out. Perhaps I haven't come across the situation with an intersection fix not on the charts in my limited experience. The whole filing thing is more to do with Lost Comms than anything else. Unless I've specifically requested the Full Procedure- ABC Transition, then, as stated by another poster, you always get vectored to final. Iain "Slav Inger" wrote in message om... Hi all, Question: take a look at the VOR Rwy 28 approach at Marshall Brooks field (RMY). I've filed IFR to airports where the VOR IAF happened to be the VOR which was no problem, I'd just have that VOR be the last fix in the route box on flight plan form. In RMY's case, the IAF appears to be the intersection ALBIO. So, on the flight plan, should the route terminate at ALBIO? That intersection isn't even on the enroute chart. Thanks. P.S. Sorry haven't posted in a while, have had no time to read or post. ![]() - Slav |
![]() "Iain Wilson" wrote in message hlink.net... The whole filing thing is more to do with Lost Comms than anything else. In the case of Lost Comm, ATC will try to track your progress either via transponder or as a primary target. Either way they will be sure the airspace is cleared to fly any approach at your filed destination. Unless I've specifically requested the Full Procedure- ABC Transition, then, as stated by another poster, you always get vectored to final. In many rural or mountainous areas, radar coverage is unavailable and you must fly complete approaches including published course reversals. -------------------- Richard Kaplan, CFII www.flyimc.com |
![]() "Richard Kaplan" wrote in message s.com... In the case of Lost Comm, ATC will try to track your progress either via transponder or as a primary target. Either way they will be sure the airspace is cleared to fly any approach at your filed destination. Or at any airport along your route. |
"Iain Wilson" wrote in message thlink.net...
My CFII's IR notes have a bold entry for "Always file to an IAF" and that's what I do. Not saying this is correct or not, hopefully this thread sorts it out. Perhaps I haven't come across the situation with an intersection fix not on the charts in my limited experience. This is actually an interesting topic. If you follow Don Brown's interesting columns for AvWeb, a few months back he emphasized "always file to an IAF". (If you don't follow them you should). On the other hand....he also made a statement indicating that he believed every approach contained an explicit transition from the Victor airway structure -- IOW, that it's straightforward to include the transition from the enroute structure to the IAF in your flight plan. (My paraphrase) Well, I think that was true once, but enter the RNAV/GPS approach where (from what I understand) it's considered a transition if an airway or intersection simply lies in one of the TAA sectors (with no charted way for ATCS or pilot to readily Get the Picture). And I know some RNAV/GPS approaches where I don't even think that's true-- certainly not of any VOR or intersection that anyone shooting the approach would realistically want to fly to, first. The bottom line is: my obsolete Palm VIIx can hold every VOR, navaid, intersection, and airport in its measily little memory, but the ATC computers can't. So if you're planning to shoot a GPS approach, or if the IAF is not part of the enroute structure and your destination is served by a different ARTCC than your departure point, there's a pretty good chance filing to the IAF will only bollix the works. OTOH, if the IAF is on the enroute charts, if it's an h-class VOR or an intersection defined by airways, file it. The whole filing thing is more to do with Lost Comms than anything else. Mmmm. Well. I have two radios, two antenna, extra headset jacks, and a handheld radio with headset adaptor. I could be wrong, but I think the most likely reason for me to lose comms (other than temporarily) would be electrical failure. In that case, I think the best thing for me to do is beat it to the nearest VFR wx. If I do lose comms for some other reason, I'm going to land at the nearest practical airport. Let's say I'm flying into BWI. Think ATC wants me to follow lost comm procs, hold at the IAF for one of the ILS then shoot the approach? Or do they want me to skedaddle down the GPS approach into some airport along the way and get out of their hair ASAP? I know which gets my vote. Unless I've specifically requested the Full Procedure- ABC Transition, then, as stated by another poster, you always get vectored to final. Um, no. If you are flying into airports where the ATC facility can provide radar vectors to the FAC, you almost always get vectored to final. However, there are many airports and many approaches where this isn't true, and you'll be flying the full approach including the PT or other course reversal. "Slav Inger" wrote in message om... Question: take a look at the VOR Rwy 28 approach at Marshall Brooks field (RMY). I've filed IFR to airports where the VOR IAF happened to be the VOR which was no problem, I'd just have that VOR be the last fix in the route box on flight plan form. In RMY's case, the IAF appears to be the intersection ALBIO. So, on the flight plan, should the route terminate at ALBIO? That intersection isn't even on the enroute chart. Slav, if the intersection isn't on the enroute chart, it's not likely to be in the ATC computers unless your departure is served by the same ATC facility. So I wouldn't file it. JMO. Best, Sydney |
GPS approaches/Filing IAF
Good to know. You'd think that anything designated as an IAF would be in the system.. The whole filing thing is more to do with Lost Comms than anything else. Mmmm. Well. I have two radios, two antenna, extra headset jacks, and a handheld radio with headset adaptor. I could be wrong, but I think the most likely reason for me to lose comms (other than temporarily) would be electrical failure. In that case, I think the best thing for me to do is beat it to the nearest VFR wx. If I do lose comms for some other reason, I'm going to land at the nearest practical airport. Let's say I'm flying into BWI. Think ATC wants me to follow lost comm procs, hold at the IAF for one of the ILS then shoot the approach? Or do they want me to skedaddle down the GPS approach into some airport along the way and get out of their hair ASAP? I know which gets my vote. Undoubtedly, but you still file a plan primarily for routing & lost comms. If there are no other more sensible actions, then you are supposed to fly what you've filed. Unless I've specifically requested the Full Procedure- ABC Transition, then, as stated by another poster, you always get vectored to final. Um, no. If you are flying into airports where the ATC facility can provide radar vectors to the FAC, you almost always get vectored to final. However, there are many airports and many approaches where this isn't true, and you'll be flying the full approach including the PT or other course reversal. Um, obviously with no radar, there'll be no vectoring. "Slav Inger" wrote in message om... Question: take a look at the VOR Rwy 28 approach at Marshall Brooks field (RMY). I've filed IFR to airports where the VOR IAF happened to be the VOR which was no problem, I'd just have that VOR be the last fix in the route box on flight plan form. In RMY's case, the IAF appears to be the intersection ALBIO. So, on the flight plan, should the route terminate at ALBIO? That intersection isn't even on the enroute chart. Slav, if the intersection isn't on the enroute chart, it's not likely to be in the ATC computers unless your departure is served by the same ATC facility. So I wouldn't file it. JMO. Best, Sydney |
"Iain Wilson" wrote in message link.net...
GPS approaches/Filing IAF Good to know. You'd think that anything designated as an IAF would be in the system.. Yeah, well. The thought that my Palm VIIx has more memory than today's ATC computers is pretty scary actually. Undoubtedly, but you still file a plan primarily for routing & lost comms. If there are no other more sensible actions, then you are supposed to fly what you've filed. My point is, and this isn't aimed at you in particular, I hear a lot of stressing over the fine points of routing "in case of lost comms". But in fact, following the route as filed is only one of several RL options in the case of lost comms, and quite likely not the best option. JMO, but if there are no other "more sensible actions" I kinda think as the pilot of a light SE airplane I should stay in the air. Unless I've specifically requested the Full Procedure- ABC Transition, then, as stated by another poster, you always get vectored to final. Um, no. If you are flying into airports where the ATC facility can provide radar vectors to the FAC, you almost always get vectored to final. However, there are many airports and many approaches where this isn't true, and you'll be flying the full approach including the PT or other course reversal. Um, obviously with no radar, there'll be no vectoring. It's not as simple as "no radar", there can be radar coverage but it must meet certain criterion for ATC to be able to provide radar vectors to the FAC. But I was addressing the statement "you always get vectored to final" T'aint so. Cheers, Sydney |
How to file XXX to XXX? | Nicholas Kliewer | Instrument Flight Rules | 13 | May 19th 04 03:12 AM |
Ron Wantaj?? XL file | Jerry Wass | Home Built | 9 | March 3rd 04 03:22 AM |
Alternate Intersection Name in Brackets? | Marco Leon | Instrument Flight Rules | 7 | January 22nd 04 04:55 AM |
initial fix an intersection | SFM | Instrument Flight Rules | 14 | November 15th 03 11:49 PM |
Identifying an intersection with options | Ben Jackson | Instrument Flight Rules | 2 | September 3rd 03 05:59 PM |
