RNP .3
Old May 30th 04, 05:36 AM
Greg Esres
Default RNP .3
What kind of equipment can be used to meet RNP .3? I'm aware of GPS
and DME/DME.
Old May 30th 04, 07:15 PM
and DME/DME.
Only GPS with either selectable scaling to 0.3, flight director, or
autoflight coupled to RNAV. DME/DME is not authorized RNP 0.3 except
with special authorization at some locations.
Old May 31st 04, 05:02 PM
Greg Esres
Thank you. In regards to the last, the instrument approach plates
that do not allow RNP 0.3 say "Not Authorized". I assme that every
plate without that IS authorized. Are you saying that the latter is
"special authorization" ?
Old May 31st 04, 08:33 PM
So far as I know, they all say:
"GPS or RNP 0.3 required. DME/DME RNP 0.3 NA."
And, the first sentence has a bit of "The Emperor has no clothes" in it,
in that it suggests there is some way of getting to RNP 0.3 in addition
to GPS. That comes from the sensor-independent concept of RNP. Trouble
is there is no sensor other than GPS around today that will do RNP 0.3.
Old June 3rd 04, 04:35 AM
Greg Esres
I thought I had found a number without that notation, but, those may
have been "GPS" approaches, rather than RNAV.
it, in that it suggests there is some way of getting to RNP 0.3 in
addition to GPS. That comes from the sensor-independent concept of
RNP. Trouble is there is no sensor other than GPS around today that
will do RNP 0.3.
That sort of discrepancy is why I'm having such a hard time preparing
a sheet that clearly describes each type of GPS-based approach and
what equipment is required to fly it.
There seems to be a lot of hand-waving going on when the FAA (or
anybody else) talks about these things. Does anyone fully understand
what's going on?
Old June 3rd 04, 01:29 PM
If it says "GPS" rather than "RNAV (GPS)" it very well may have no note at
all. But, since most of the legacy LNAV suites are in Part 121
operations, those approaches aren't approved under op specs in any case.
will do RNP 0.3.
what's going on?
Nope. Too many snake oil salemen stirring the soup.
