Rule of thumb fudge factor
Old July 3rd 06, 10:48 PM posted to rec.aviation.soaring
Slick
Default Rule of thumb fudge factor
What is the rule of thumb to reduce the L/D when plotting a cross country
flight?
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
Old July 3rd 06, 11:14 PM posted to rec.aviation.soaring
Half.
flight?
Old July 4th 06, 01:45 AM posted to rec.aviation.soaring
With experience you can evaluate the conditions of the day and adjust
accordingly. If winds are light and lift is good you can use 2000ft
margin to arrive at the next landable location. Even on a good day I
use 85% of the L/D plus a safety margin.
If you examine the flights of experienced pilots they at time appear to
take much larger risks but it is because they can judge the conditions
and anticipate changes that they are able to do this successfully.
Be careful at first as you can get into trouble fast especially on days
where the wind is blowing.
Half.
flight?
Old July 4th 06, 02:14 AM posted to rec.aviation.soaring
BTIZ
1/2 the planned L/d
BT
"Slick" wrote in message
flight?
News==----
Newsgroups
Old July 4th 06, 02:39 AM posted to rec.aviation.soaring
Eric Greenwell[_1_]
flight?
My experience with gliders ranging from a Ka-6e to an ASH 26 E is a
McCready setting of 4 on the glide calculator gives me a very high
probablity of making it to my selected landing place (usually an
airport). I don't set the speed-to-fly at 4, but at 2 or less, depending
on the conditions. My arrival height setting is 1000 feet agl.
In areas with poor landing possibilities, like a glide over a forest,
lake, and other unlandable areas, I'll increase the MC setting to 5,
perhaps even 6. If wave is about, it can be a real guessing game, and
I'll generally use even higher settings. A setting of 4 is about 60% of
maximum L/D.
Be sure your planning allows for the usual winds.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old July 4th 06, 05:13 PM posted to rec.aviation.soaring
Jean
I use 2 different calculations:
- Safety to reach a landable field: Typically 1/2, plus or minus according
to the wind
- Realistic transition (where a miss wouldn't be dangerous): 2/3
Jean
"Slick" a écrit dans le message de news:
flight?
News==----
Newsgroups
rule of thumb: take off distance and weight [email protected] Piloting 2 March 27th 05 10:54 AM
FAA Mandatory Pilot Retirement Rule Challenged Larry Dighera Piloting 0 March 20th 05 08:56 PM
F/A-18 approach speed rule of thumb tscottme Naval Aviation 5 December 6th 04 11:13 PM
Wind rule of thumb? Bart Rotorcraft 3 April 29th 04 02:18 PM
