Hi,
Club aircraft has a GARMIN GNC 300XL TSO which according to the spec, has a PC interface. Is there any software out there that I can run from a PC to enter routes, waypoints etc directly into the device? Having a PC interface is one thing, being able to use it without resorting to the SDK is another. Not sure whether the device came with the appropriate cable, but I assume you can buy one from Garmin. Any help/advice appreciated. Thanks, Kevin |
It does not have a PC interface, but you can pull it out of the panel and
hook it up to a 12 volt power supply......that Garmin will sell you or you can buy at Radio Shack. Then you can program all the user waypoints and routes while in "simulator" mode. This is also a good way to learn exactly how to use the somewhat outdated and unfriendly user interface. Karl, IFR GPSs I've owned and learned....... GPS 155 (really bad software) GPS 155XL, 300XL (slightly better software) GNS 430 (Vastly superior software, but far from great!) CNX 80 (Great software, but steep learning curve for non-FMS trained pilots) "Curator" N185KG "KevinBlack" wrote in message ... Hi, Club aircraft has a GARMIN GNC 300XL TSO which according to the spec, has a PC interface. Is there any software out there that I can run from a PC to enter routes, waypoints etc directly into the device? Having a PC interface is one thing, being able to use it without resorting to the SDK is another. Not sure whether the device came with the appropriate cable, but I assume you can buy one from Garmin. Any help/advice appreciated. Thanks, Kevin |
Karl,
Thanks, we have it out of the panel with an appropriate power supply. I was curious about the PC software to achieve this? Apologies for my relative ignorance, but what software do we run on the PC to generate the routes/waypoints to upload to the GPS - or am I missing something fundamental? Cheers, Kevin "karl gruber" wrote in message ... It does not have a PC interface, but you can pull it out of the panel and hook it up to a 12 volt power supply......that Garmin will sell you or you can buy at Radio Shack. Then you can program all the user waypoints and routes while in "simulator" mode. This is also a good way to learn exactly how to use the somewhat outdated and unfriendly user interface. Karl, IFR GPSs I've owned and learned....... GPS 155 (really bad software) GPS 155XL, 300XL (slightly better software) GNS 430 (Vastly superior software, but far from great!) CNX 80 (Great software, but steep learning curve for non-FMS trained pilots) "Curator" N185KG "KevinBlack" wrote in message ... Hi, Club aircraft has a GARMIN GNC 300XL TSO which according to the spec, has a PC interface. Is there any software out there that I can run from a PC to enter routes, waypoints etc directly into the device? Having a PC interface is one thing, being able to use it without resorting to the SDK is another. Not sure whether the device came with the appropriate cable, but I assume you can buy one from Garmin. Any help/advice appreciated. Thanks, Kevin |
"karl gruber" writes:
It does not have a PC interface, ....and yet one of the optional accessories is "PC Software/Interface Kit". http://www.garmin.com/manuals/GNC300...ilotsGuide.pdf Why would Garmin say that if it does not have a PC interface? --kyler |
GARMIN GNC 300XL TSO - Using the PC Interface | KevinBlack | Piloting | 9 | July 8th 06 08:25 PM |
Garmin 300XL GPS Approach didn't arm | Steve S | Instrument Flight Rules | 9 | May 11th 06 02:54 AM |
EW to Garmin 196 interface problem | Cliff Hilty | Soaring | 2 | May 3rd 06 01:02 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Many manuals and POH for auction, C402B, C177RG, C172, Garmin 300xl | E-man | Piloting | 0 | December 15th 05 03:08 AM |
