Cananian airspace
Old June 25th 04, 03:02 AM
Mike Rapoport
Default Cananian airspace
What type of airspace is the restricted airspace north of Vancouver Island.
Flightmap lists it as COMOX and says that it reaches from 18,000MSL to
Unlimited. It is big, about 165nm on the NS axis and 110nm EW. What are my
chances at getting cleared through it at FL240?
Thanks!
MU-2
Old June 25th 04, 03:12 AM
Paul Tomblin
What's the designation?
....would you work for a company that couldn't tell the difference in
quality of its employees' normal work product and the work product of
someone on drugs without performing a test? -- socks
Old June 25th 04, 03:34 AM
Mike Rapoport
Flightmap shows no information except the name "Comox" the altitudes
"18,000/Unlimited" and that "Comox Terminal Control" is the controlling
agency.
MU-2
Island.
my
Old June 25th 04, 04:38 AM
Ender
agency.
MU-2
More than likely something to do with CFB Comox
I dunno your chances of getting through though I'd speculate they're
pretty good.
Old June 25th 04, 04:50 AM
Rob McDonald
That would be CFB Comox, i.e. a military base.
Rob
"Mike Rapoport" wrote in
link.net:
Island. Flightmap lists it as COMOX and says that it reaches from
18,000MSL to Unlimited. It is big, about 165nm on the NS axis and
110nm EW. What are my chances at getting cleared through it at FL240?
Thanks!
MU-2
Old June 25th 04, 11:53 AM
Ah yes, area " Nighthawk", reserved for (then) CF-101 Voodoos doing
intercept training. When not using the area, it was given back to
Vancouver center (?) and airliners did indeed use it. The voodoos
left in 1984, replaced for at least a short time by CF 18s. I don't
know if there are still CF 18s at Comox.
Simplest is to call the base at Comox, 250-339-8231 ask for ATC, and
ask them for what's likely to happen reference this area. Failing
that, try Vancouver center, 604-775-9601
Good luck on your trip to Alaska
Stan
On Fri, 25 Jun 2004 02:02:25 GMT, "Mike Rapoport"
Thanks!
MU-2
Old June 25th 04, 11:54 AM
Brendan Grace
I don't have my Vancouver Map handy but that should be the
military control zone (Class D) for CFB Comox. Very low military
traffic and a great bunch in their ATC facility. Should be no
problem but you can always check with them first while flight
planning. If you enter through Victoria you can verify with the
local FBO as to current local procedures. Haven't flown there
lately but lots of friends out there and they have no problems.
Brendan Grace
"Ender" wrote in message
news:L6NCc.13447$HS3.6334@edtnps84...
altitudes
controlling
agency.
MU-2
they're
pretty good.
Old June 25th 04, 12:29 PM
Paul Tomblin
I think all the CF-18s in Canada are back in Trenton. And at least 2/3rds
of them are in a warehouse in Trenton.
Paul Tomblin
"Almost any animal is capable of learning a stimulus/response association,
given enough repetition. Experimental observation suggests that this
isn't true if double-clicking is involved." -Lionel Lauer and Malcolm Ray
Old June 25th 04, 02:35 PM
Mike Rapoport
Thanks for the great info. I'll let you know what happens.
MU-2
Stan
Island.
my
Thanks!
MU-2
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
most of eastern Massachussetts airspace closed in July Christopher C. Stacy Instrument Flight Rules 29 June 19th 04 12:47 AM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
airspace G Jim Anglin Home Built 8 February 22nd 04 11:29 PM
Airspace Privacy over your house !!!!!!!!!!!!!!!!!!!!!!! Fitzair4 Home Built 26 December 12th 03 12:48 AM
