Non-precision approach without a published MAP?
Old July 30th 06, 04:34 PM posted to rec.aviation.ifr
Peter R.
Default Non-precision approach without a published MAP?
Last Friday I flew with another pilot to Starke County, Indiana (KOXI) to
pick up my stranded Bonanza.
The airport is only served by one instrument approach, a VOR/GPS approach,
linked he
http://www.myairplane.com/databases/.../06847VG18.PDF
Until this approach, I had not encountered a non-precision approach without
a published missed approach point. Is this more common than my experience
has provided to date?
Peter
Old July 30th 06, 04:40 PM posted to rec.aviation.ifr
Peter R.
Just after sending this up, I recalled a discussion in this group about a
year ago that talked about VOR approaches whereby the VOR is on or very
close to the field. I then pulled up a couple of other approaches to
nearby airports where this is the case and the VOR serves as the MAP.
My confusion was a result of expecting to see the point published on the
chart as MAP, but apparently these types of approaches imply the MAP is at
the VOR without needing to specifically label them as such.
I do not have the Jepp subscription to the chart linked in my previous
post, but I will pull up my Jepps to see how they chart the MAP on nearby
approaches similar to this one.
Peter
Old July 30th 06, 04:51 PM posted to rec.aviation.ifr
Jim Carter[_1_]
The profile view on the approach plate illustrates that the MAP is at
the VOR/DME.
-----Original Message-----
From: Peter R. [mailto Posted At: Sunday, July 30, 2006 10:40
Posted To: rec.aviation.ifr
Conversation: Non-precision approach without a published MAP?
Subject: Non-precision approach without a published MAP?
without
experience
a
at
nearby
Peter
Old July 30th 06, 05:23 PM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
linked he
Unless I am missing something obvious, the VOR is the missed approach
point. There are hundreds (thousands?) of approaches like this where
the missed begins at the navaid.
Old July 30th 06, 06:08 PM posted to rec.aviation.ifr
Dave S
linked he
It also occurs BEYOND the departure end of the runway...
Old July 30th 06, 06:27 PM posted to rec.aviation.ifr
linked he
So what? I would consider a MAP that begins before the runway to be an
exception rather than the rule. That's what VDP's are for. Here are a
few VOR approaches that begin beyond the departure end of the runway.
http://www.myairplane.com/databases/...s/00958V24.PDF
http://www.myairplane.com/databases/.../00863VG33.PDF
http://www.myairplane.com/databases/...s/00863VG6.PDF
http://www.myairplane.com/databases/.../00583VG4L.PDF
Old July 30th 06, 11:31 PM posted to rec.aviation.ifr
Dave S
I agree..
But what I am referring to were MAPs that are reached after you have
already passed the runway completely (approach AND departure end), and
are leaving the airport boundary, which is portrayed in the approach in
question. I'm sure there are more than a few.. I just haven't seen many
like that.
Dave
Old July 31st 06, 02:22 PM posted to rec.aviation.ifr
Sam Spade
I agree..
like that.
Dave
That's why it's called a non-precision approach. You are suppose to
understand on on-airport-faciliy's IAP limitations and be guided
accordingly.
These are antiques now.
Old July 30th 06, 09:21 PM posted to rec.aviation.ifr
Sam Spade
(KOXI) to
approach,
linked he
without
experience
I think you meant to say the MAP occurs beyong the approach end of the
runway.
VOR and NDBs that are located on the airport are "on airport" approach
facilities. The missed approach point is the facility even though it is
beyond the landing threshold. The only exception is where it is a
VOR/DME IAP, then a DME fix at the threshold will mark the MAP.
Old July 30th 06, 08:03 PM posted to rec.aviation.ifr
Peter R.
In retrospect my confusion may be due to the differences between Jepp
charts and the NACO charts. The Jepp charts include the M on these types
of approaches to indicate the MAP.
From the first days of instrument training I used Jepps over NACO charts
and had grown into thinking that this visual indicator was the method for
indicating the MAP on both types of charts.
The approach linked in my original post was the first VOR approach I flew
outside my Jepp subscription (the Northeast US).
Peter
Our first IFR cross-country trip: NY-MI-IL-MI-NY Longworth Piloting 16 July 15th 05 08:12 PM
Video of VOR A approach into MBO in actual A Lieberman Instrument Flight Rules 1 May 2nd 05 03:35 PM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
Backup gyros - which do you trust? Dan Luke Piloting 23 July 17th 03 08:06 PM
