Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Mounting "portable" avionics
Old July 31st 06, 12:33 AM posted to rec.aviation.owning,rec.aviation.products
Andrew Gideon
Default Mounting "portable" avionics
Our club aircraft have GNS-430s and Strikefinders, but I'm looking at
adding some additional capacity. Long term, I suspect that ADS-B plus an
MFD is going to be the way to go. But ADS-B coverage is a little light
right now, so I'm reluctant to have members spending money today for such
limited capability. Yet I'm also reluctant to spend lots of money on
something to be replaced in the not too distant future.
One solution is to go with some portable device for WX etc. This has
additional advantages, like backup power and the like. And even though
we've standby vacuums, I'm also attracted to portables with some sort of
solid state AI backup.
The VistaNav and Cheetah 190 are high on my list.
But I'd like to have some type of "semi-permanent" mounting solution. It
should make the device tough to remove (although not impossible) and
should not be too annoying to the pilot not using the gear. I'm
especially interested in this to simplify the usual "wiring mess" which
portables with multiple add-ons impose.
What's possible?
Obviously, cost is a factor. So something that doesn't require a 337,
multiple inspections, a five-foot stack of paperwork, etc. would be
preferable.
Suggestions/recommendations?
Thanks...
Andrew
http://flyingclub.org/
Old July 31st 06, 02:45 AM posted to rec.aviation.owning,rec.aviation.products
Bob Noel
What's possible?
would ram-mounts be useful for you?
Bob Noel
Looking for a sig the
lawyers will hate
Old August 1st 06, 08:53 PM posted to rec.aviation.owning,rec.aviation.products
Andrew Gideon
I don't know; I'm not familiar with this. But it lead me to:
http://www.aircraftspruce.com/menus/av/mounts.html
which looks like it has some promise.
This, for example:
http://www.aircraftspruce.com/catalo...ssnarailmt.php
looks "attractive". I've long wanted a cup holder, for example laugh!
It doesn't seem like it solves any wiring problems, though. Am I missing
something?
And can these be installed by anyone? Is it a 337 sort of thing (I'm
thinking of problems with Cessna seat rails in the past)?
Thanks...
Andrew
Old August 2nd 06, 03:47 AM posted to rec.aviation.owning,rec.aviation.products
Newps
This, for example:
something?
They are not installed. They are portable.
Old August 3rd 06, 05:09 AM posted to rec.aviation.owning,rec.aviation.products
Mike Noel
I don't think this discussion was about panel mounting portable avionics,
but I thought I would share what 'Dave' the avionics guy at our airport told
me. I want to remove my old clunker ADF from the copilot side and install
an airgizmo mount with the 15 degree angle adapter. He thinks since the
hole will already be there from removing the ADF, the only paperwork
necessary is updating the maintenance logs and the weight-and-balance
information.
Hope he's right.
Best Regards,
http://photoshow.comcast.net/mikenoel
news
This, for example:
something?
Thanks...
Andrew
Old August 3rd 06, 03:56 PM posted to rec.aviation.owning,rec.aviation.products
Newps
There are several articles lately about installing the Air Gizmos mount.
Mike Busch has been one of the most vocal. According to him and
others this mount is the very definition of a minor alteration.
information.
Hope he's right.
Old August 7th 06, 09:32 PM posted to rec.aviation.owning,rec.aviation.products
Andrew Gideon
Yet:
http://www.airgizmos.com/faq.asp
includes:
Q: Can the Panel Dock be installed in a certified aircraft?
A: The Panel Dock can be installed in a certified aircraft, but you will
need an FAA field approval.
Why would the manufacturer provide misinformation that raises the cost of
its product?
Where have these articles appeared? I'd like very much to read them.
Thanks...
Andrew
Old July 31st 06, 06:26 AM posted to rec.aviation.owning,rec.aviation.products
J. Severyn[_1_]
news
What's possible?
preferable.
Thanks...
Andrew
Panel Dock for several portable GPS/WX devices might work. I've seen these
mounted in homebuilts and they help reduce the "wire tangle", but your "high
on my list" avionics are not on the airgizmo list.
http://www.airgizmos.com/index.asp
John Severyn
@KLVK
Mounting "portable" avionics Andrew Gideon Owning 11 August 8th 06 08:51 AM
Frying your avionics ELIPPSE Home Built 13 July 25th 06 09:31 PM
IGC-approval issued for EW Avionics microRecorder Ian Strachan Soaring 0 June 11th 06 05:52 PM
Has Anyone Used The "Approach Sport Hub Avionics Wiring Systems"? three-eight-hotel Owning 7 June 1st 06 03:28 PM
Used Avionics O. Sami Saydjari Instrument Flight Rules 40 December 2nd 03 02:53 PM
