Microbursts
Old August 3rd 06, 08:28 AM posted to sci.physics,rec.aviation.hang-gliding,rec.aviation.soaring
Default Microbursts
Remarkably valuable material is available these days on wikipedia.
But I've got problems with this
http://en.wikipedia.org/wiki/Microburst
text.
Sailplaners will have a good understanding of natural air flow.
This text seems to suggest that you can take an unenclosed 'parcel'
of air, and move it through the surounding air, like you can throw
a solid object through the air.
I can't find good explanations of why the text is 'wrong'.
Microburst
From Wikipedia, the free encyclopedia
[5]A photograph of the surface curl soon after an intense microburst
impacted the surface
A falling potatoe may 'impact' the floor, but air can't impact the floor
any more than a 'swirl' [being a separate volume of the liquid] inside
your coffee cup can impact the surface.
A microburst is a very localized column of sinking air, producing
damaging divergent and [7]straight-line winds at the surface that are
similar to but distinguishable from [8]tornadoes which generally have
convergent damage.
The 'localisation' is the problem.
To move a small volume with respect to its surroundings, you have to
apply energy to this 'localisated package' and not to its surroundings.
I guess lightning/thunder does that ?
Perhaps a laser could too.
The term was defined by severe weather expert [9]Tetsuya Theodore
Fujita as affecting an area 4 km (2.5 mi) in diameter or less,
distinguishing them as a type of [10]downbursts and apart from common
[11]wind shear which can encompass greater areas. Dr. Fujita also
coined the term macroburst for downbursts larger than 4 km (2.5 mi).
A distinction can be made between a wet microburst which consists of
precipitaiton and a dry microburst which consists of [12]virga. They
generally are formed by precipitation-cooled air rushing to the
surface, but they perhaps also could be powered from the high speed
windsofthe [13]jet stream deflected to the surface in a
[14]thunderstorm (see [15]downburst).
Microbursts are recognized as capable of generating wind speeds higher
than 75 m/s (168 mph; 270 km/h).
Danger to aircraft
See also: [17]downbursts
The scale and suddenness of a microburst makes it a great danger to
aircraft, particularly those at low altitude which are taking off and
landing.The following are some fatal crashes that have been
attributed to microbursts in the vicinity of airports:
* [18]Delta Air Lines Flight 191
* [19]Eastern Air Lines Flight 66
* [20]Pan Am Flight 759
* [21]USAir Flight 1016
A microburst often causes aircraft to crash when they are attempting
to land. The microburst is an extremely powerful gust of air that,
once hitting the ground, spreads in all directions. As the aircraft is
coming in to land, the pilots try to slow the plane to an appropriate
speed. When the microburst hits, the pilots will see a large spike in
their airspeed, caused by the force of the headwind created by the
microburst. A pilot inexperienced in microbusts would try to decrease
the speed. The plane would then travel through the microburst, and fly
into the tailwind, causing a sudden decrease in the amount of air
flowing across the wings. The sudden loss of air moving across the
wings causes the aircraft to literally drop out of the air. The best
way to deal with a microburst in an aircraft would be to increase
speed as soon as the spike in airspeed is noticed. This will allow the
aircraft to remain in the air when traveling through the tailwind
portion of the microburst.
OTOH I've heard the big-jet's 'exhaust' and downwash also
'stays together like a solid' and doesn't disperse.
How much of this is true ?
If you've got a conical bucket of white-water, with a mechanism
to close off the lower 25% of the cone, can you project a black-ball
of water down through the white-water, and capture it by closing
of the lower clone section ?
Or will the black-ball of water just be dispersed ?
If an aircraft/bomber had it's front blown-off so that the
pilots had no shielding in front of them, would they necessarily have
near flying speed winds 'impacting' them, if the airflow had no
'reason' to flow in, 'cos it's got no low resistance path to flow out ?
== Chris Glur.
Old August 3rd 06, 04:31 PM posted to sci.physics,rec.aviation.hang-gliding,rec.aviation.soaring
Default Microbursts
Have you ever seen someone blow smoke rings? Eventually they disperse,
but they can stay together for a surprising amount of time.
text.
Microburst
convergent damage.
Danger to aircraft
== Chris Glur.
Old August 3rd 06, 04:46 PM posted to sci.physics,rec.aviation.hang-gliding,rec.aviation.soaring
Floyd Rogers
Default Microbursts
text.
Microburst
convergent damage.
Read the explanation of "downdraft" and "gust front", beginning on
page 247 in Pagen's "Understanding the Sky". Note particularly:
"...brings a shift in wind up to 180 degrees ..., an increase in velocity
commonly around 30 mph BUT OCCASIONALLY SEVERAL TIMES
this amount..." (Emphasis mine.)
National Audubon Society's "Field Guide to North American Weather"
also has an excellent explanation on pp 104-5, and an explanation of
plates 202-5 on p.509.
Might be hard to find the field guide in South Africa. ;-
FloydR
Old August 3rd 06, 06:15 PM posted to rec.aviation.soaring
Nyal Williams
Default Microbursts
Point this out to those who de-ride (pun intended)
the High Parasitic Drag Approach.
you have to
Don't have time to get into details, but the best example
of
microbursts here in Colorado, is the 'virga bomb' as
often mentioned in
a forecast discussion.
The air is dry, there's a thunderstorm with cloudbase
at 18K or so. It
starts raining, so there is a localized parcel of air
containing
raindrops. As the rain falls, it evaporates due to
the dry air below.
The evaporation pulls heat from the nearby air and
it rapidly chills.
This cool air is now much heavier and begins to fall
faster, etc, etc.
I've been in situations where the air is falling so
fast, that in a 45
or more degree nose down attitude, my airspeed is still
decreasing (in
an ASW-20B). Luckily, the few times I've encountered
this, I was in or
near the landing pattern, and I flew out the side before
reaching the
ground. Others have not been so lucky, and end up
'landing' in
whatever is nearly directly below them.
-Tom
Old August 3rd 06, 07:58 PM posted to sci.physics,rec.aviation.hang-gliding,rec.aviation.soaring
Sorcerer
Default Microbursts
| text.
| Microburst
microburst
| convergent damage.
also
| Danger to aircraft
| == Chris Glur.
Wackypedia can be edited by anyone, so you'll inevitably get
nut case rants along with solid information. Jimbo Wales doesn't care
as long as he profits by it.
Androcles.
Old August 3rd 06, 10:19 PM posted to sci.physics,rec.aviation.hang-gliding,rec.aviation.soaring
tadchem[_1_]
Default Microbursts
snip
I think you may be reading too much into the word "impact." A
microburst is simply a wind that blows *downward* - usually in
association with a cloudburst-type thunderstorm.
What word would *you* use to describe what happens to a wind that is
moving downward at considerable speed and then runs into the ground?
It is the same effect as a regular wind running into a wall, only
rotated 90 degrees.
convergent damage.
Gravity combined with the viscous drag of falling raindrops and the
cooling effect of trhe evaporation of the falling rain (to compress the
air, making it more dense) does the trick. On the Great Plains of
the US I have seen cloudburst thunderstorms less than a km across.
You'll see the same in deserts.
Not enough energy, not directed. - thunder is omnidirectional,
lightning is too fast and too localized (a few cm wide) to overcome the
inertia of a large mass of air.
No, for the same reasons that lightning can't do the job. Also, we
have no lasers anywhere near energetic enough. In Amarillo, TX one
afternoon I witnessed a damaging downburst that peeled the sheet metal
roof of a 110' square building and crumpled it like aluminum foil, but
left adjacent structures untouched. The weather service estimated the
speed at 100 mph. [The building had previously withstood 60 mph winds.]
Google "vortex gun" and find some interesting pages, including this:
http://amasci.com/amateur/vortgen.html
which has a crude but accurate animation of a travelling vortex of air.
Make your own long-range vortex generator for a few pennies:
http://www.geocities.com/davidvwilliamson/vortex.html
Or buy one pre-made for a few bucks:
http://dansdata.com/airzooka.htm
Tom Davidson
Richmond, VA
Old August 3rd 06, 10:32 PM posted to sci.physics,rec.aviation.hang-gliding,rec.aviation.soaring
CWatters
Default Microbursts
Yes but that's not a problem. Read up on how thermals are produced. A micro
burst isn't that different. It's a bit like a strong "anti thermal". ... The
sun warms up a large area then a small rain cloud cools part of it causing
that part to sink rapidly.... is one way to look at it. The ultimate source
of the energy is the sun just the same as for a thermal.
Old August 4th 06, 12:51 AM posted to sci.physics,rec.aviation.hang-gliding,rec.aviation.soaring
Bill Daniels
Default Microbursts
"5Z" wrote in message
Don't have time to get into details, but the best example of
microbursts here in Colorado, is the "virga bomb" as often mentioned in
The air is dry, there's a thunderstorm with cloudbase at 18K or so. It
starts raining, so there is a localized parcel of air containing
raindrops. As the rain falls, it evaporates due to the dry air below.
The evaporation pulls heat from the nearby air and it rapidly chills.
This cool air is now much heavier and begins to fall faster, etc, etc.
I've been in situations where the air is falling so fast, that in a 45
or more degree nose down attitude, my airspeed is still decreasing (in
an ASW-20B). Luckily, the few times I've encountered this, I was in or
near the landing pattern, and I flew out the side before reaching the
ground. Others have not been so lucky, and end up "landing" in
-Tom
To 5Z, yep! BT,DT got the t - shirt.
The real power behind downburst is the amazing amount of heat it takes to
evaporate the raindrops before they hit the groumd. This cooling effect
chills millions of tons of air that litterally free falls to earth. The
impact has leveled humdreds of square miles of forrest in "blowdown areas"
across the western USA.
They can be seen as they happen. First virga appears below a high based Cu
Nim then a dust ring appears on the ground below. The dust ring can grow
until it's miles across.
The good news is that the mass of falling air displaces warm air near the
surface creating a ring of strong, smooth lift around the downburst - a good
thing since you don't want to land anywhere near one.
Bill Daniels
Old August 4th 06, 12:55 AM posted to sci.physics,rec.aviation.hang-gliding,rec.aviation.soaring
Floyd Rogers
Default Microbursts
| text.
Actually, the microburst article (as well as most wikipedia entries, IME)
is quite good, as far as it goes. The text is very close to that in the two
references (Pagen, NAS Field Guide) that I mentioned, as are the
explanations.
FloydR
