360 Comm
Old August 3rd 06, 06:38 PM posted to rec.aviation.homebuilt
Tri-Pacer[_1_]
Default 360 Comm
Does anyone have an old 360 Comm they'd let go cheap?
I'd like to get a transistorized one that I could run with a 12VDC wall
wart.
My hangar is in a row perpendicular to the runway. I'm about in the center.
That means I stop what I'm doing about every 10 minutes and go to the end of
the row to see what that interesting sounding airplane
is.
I want to put a receiver in a box with a speaker and know if the plane
landing or taking off is my buddy or something interesting.
The transmit portion can be dead.
Thanks
Paul
N1431A
paul-anton at comcast dot net
Old August 4th 06, 02:53 AM posted to rec.aviation.homebuilt
pro
Default 360 Comm
You would be better off with an scanner that tunes aircraft. Then you
could scan the tower and ground, and atc. I tried what you are doing,
but had to run back and forth to change freqs every few minutes...found
an old scanner at a yard sale for 5 bucks and set it up in the hanger...
wart.
is.
Thanks
Paul
N1431A
Old August 4th 06, 10:41 PM posted to rec.aviation.homebuilt
Default 360 Comm
I have a CoMM 11 Narco I'd part with for $35.
I'd guess it would need an speaker like a powered
computer one since it puts out 1v type audio.
Bill Hale Loveland CO
wart.
is.
Thanks
Paul
N1431A
Old August 5th 06, 05:09 PM posted to rec.aviation.homebuilt
Tri-Pacer[_1_]
Default 360 Comm
Shoot me an address and I'll send a check.
I'm glad you mentioned the amplified speaker idea.
Thanks much
Paul Anton
" wrote in message
wart.
center.
of
is.
Thanks
Paul
N1431A
King Comm Tom Cummings Owning 2 September 13th 04 08:01 PM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
Buying a used COMM res Owning 8 January 24th 04 05:46 AM
Lost comm altitude? Roy Smith Instrument Flight Rules 12 January 11th 04 01:29 AM
WinPilot ADV comm port setting Ted Wagner Soaring 1 December 29th 03 06:44 PM
Copyright Đ2004-2025 AviationBanter.
