Instrument Approaches in High Winds
Old August 3rd 06, 05:07 PM posted to rec.aviation.ifr
[email protected][_1_]
Default Instrument Approaches in High Winds
Hi folks,
Had a bit of adventure the other night - I was in Stockton, CA on
business. Got back to
the airport in the afternoon, and the winds were up something fierce.
Ground reports from
home in SQL showed pretty nasty winds, too. I think it was 15G22 right
across the
runway. So instead of going home, I went to Fresno, where I had
business to do anyway.
FAT was reporting W290@20 - nasty enough, but not gusting and right
down the runway.
And I figured it would only get better, because the sun - the engine
that drives high afternoon
winds in the Valley - was down. Sure enough, the FAT atis dropped to
16, then 12 knots
as I flew.
However, my actual destination was FCH, a nearby uncontrolled
field. The pattern was
uncomfortable, pitch black, high winds, and turbulence. After
landing, I thought - "Gee,
an ILS would have been nice". Or at least a GPS approach. Not because
of bad visibility - it
was severe clear except for being dark - but rather because instrument
approaches do
not feature much maneuvering at low altitudes. And I personally find
turbulence more
comfortable if I'm not turning..... Next time this happens, I might
just swing over to FAT
and use the ILS.
- Jerry Kaidor (
Old August 3rd 06, 05:40 PM posted to rec.aviation.ifr
Jim Macklin
Come to Kansas for a few days, any time of the year. We
often have winds that are 25G40, most of our runways are
pretty well laid out, but some airports do require a
crosswind landing. Of course, we routinely solo students as
long as the wind is less than 25 knots and the gusts are
minimal. But since this is Kansas, where the wind comes
sweeping down the plains, we often can have a solid day or
two of steady 25 to 40 knot winds. Our bad weather starts
at 60 knots with 2 inch hail (a golf ball is 1-3/4 inch).
One day I remember watching the airliners land. It was calm
and they all were landing very long, those calm winds are a
real problem.
James H. Macklin
ATP,CFI,A&P
| Hi folks,
Stockton, CA on
something fierce.
| Ground reports from
was 15G22 right
| across the
where I had
and right
| down the runway.
the engine
dropped to
| 16, then 12 knots
| as I flew.
uncontrolled
After
Not because
because instrument
| approaches do
personally find
| turbulence more
happens, I might
| and use the ILS.
| - Jerry
Kaidor (
Old August 4th 06, 12:38 AM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
real problem.
James H. Macklin
ATP,CFI,A&P
That was exactly my observation too when I lived in Albuquerque. I used
to solo students at 25 knots. When I moved east, I got all kind of
weird looks and comments like "test pilot" and "against the aircraft
certificaton" etc.. when I tried to send students in more than 10
knots.
Old August 4th 06, 02:19 AM posted to rec.aviation.ifr
Matt Whiting
real problem.
James H. Macklin
ATP,CFI,A&P
knots.
If the 25 knots was orthogonal to the runway, then I understand the
weird looks. If it was a headwind aligned with the runway, then not a
big deal. Taxiing might be a little interesting if the trainer is a
C152, but landing should be easy ... and very short!
Matt
Old August 4th 06, 04:05 AM posted to rec.aviation.ifr
I guess what I was trying to say was those who live in less windy areas
tend to think of the "demonstrated crosswind" are a real limitation.
real problem.
James H. Macklin
ATP,CFI,A&P
knots.
Matt
Old August 4th 06, 07:01 AM posted to rec.aviation.ifr
Jim Macklin
I have taken off with calm winds and had 40 knots 1/2 an
hour later. If you don't teach students to fly in strong
winds, you are not preparing them for changes in the
weather.
First solo at 25 knots isn't a problem, we have probably
flown many dual lessons at 25 knots or more. We also seek
out strong crosswinds.
James H. Macklin
ATP,CFI,A&P
"Andrew Sarangan" wrote in message
students as
or
starts
inch).
calm
are a
| real problem.
| James H. Macklin
| ATP,CFI,A&P
Albuquerque. I used
kind of
the aircraft
than 10
| knots.
Old August 4th 06, 07:03 AM posted to rec.aviation.ifr
Jim Macklin
Positioning the flight controls properly is essential. Too
many pilots trained in calm winds only [It windy today
should mean go fly, too often it is a day for ground school]
only. They are always at the mercy of any weather change.
James H. Macklin
ATP,CFI,A&P
"Matt Whiting" wrote in message
students as
or
starts
inch).
calm
are a
| real problem.
| James H. Macklin
| ATP,CFI,A&P
Albuquerque. I used
all kind of
the aircraft
more than 10
| knots.
understand the
runway, then not a
trainer is a
| Matt
Old August 4th 06, 07:08 AM posted to rec.aviation.ifr
Jim Macklin
Yes, they do think that. It is a fact that was just as much
wind as was blowing the day they did the proving test for
certification. The FAR 23 sets a minimum wind as a function
of stall speed, but with proper technique the actual limit
is much higher. Just to make the point, if the runway is
3,500 x 150 feet and the crosswind is 40 knots, you can land
at an angle on the runway, reducing the crosswind component.
James H. Macklin
ATP,CFI,A&P
windy areas
limitation.
We
are
students as
are
comes
day or
starts
inch).
was calm
are a
| real problem.
| James H. Macklin
| ATP,CFI,A&P
Albuquerque. I used
all kind of
more than 10
| knots.
understand the
runway, then not a
trainer is a
| Matt
Old August 4th 06, 10:06 AM posted to rec.aviation.ifr
David Cartwright
"Jim Macklin" wrote in message
news:9HCAg.85011$ZW3.63530@dukeread04...
Couldn't agree more. When I was training, we experienced the aircraft's
maximum headwind and crosswind at various times, and it was valuable
experience - if only to demonstrate that the wing didn't bang into the
ground even though it looked like it was going to! And I remember the first
calm day - landed considerably further into the runway than ever before!
D.
Old August 4th 06, 11:20 AM posted to rec.aviation.ifr
Matt Whiting
Yes, that is true. I learned at a mountaintop airport in PA with an
east/west runway, but with a large valley (called the PA Grand Canyon)
that runs north/south just southwest of the airport that channels the
prevailing west wind into a north of south wind right across the runway.
The only crosswind limitation I was taught was running out of rudder.
and even then, you could land on the grass strip as it would take a
little bit of lateral misalignment at touchdown.
I don't know what the limit for a Skylane is, but I've landed in 18K
crosswinds before. Since I never crashed it, I don't really know the
limit. :-)
Matt
Definition of simulated instrument conditions bsalai Instrument Flight Rules 14 February 4th 06 11:33 PM
Cleared for an approach, then given a different altitude assignment Peter R. Instrument Flight Rules 42 December 11th 04 04:44 PM
Tips on Getting Your Instrument Rating Sooner and at Lower Cost Fred Instrument Flight Rules 21 October 19th 04 07:31 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Logging instrument approaches Slav Inger Instrument Flight Rules 33 July 27th 03 11:00 PM
