Hirth
Old August 10th 06, 08:19 PM posted to rec.aviation.homebuilt
chuck
Default Hirth
I know that just about everybody has bad-mouthed the 2si, but what are your
opinions of the Hirth series?
Old August 15th 06, 05:17 AM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
Default Hirth
In the past, lots of reports of quality control issues, vibration problems,
etc. but they seem to have worked out the kinks, or at least the latest
reports point in that direction. The US distributor knows his stuff, but he
can only sell product as good as the factory puts out. Personal opinion.
"chuck" wrote in message
Posted via a free Usenet account from http://www.teranews.com
Old August 15th 06, 01:08 PM posted to rec.aviation.homebuilt
chuck
Default Hirth
Thank you,
I guess it'll have to be Rotex. Sure is nice to get different opinions from
the users.
"Juan Jimenez" wrote in message
problems, etc. but they seem to have worked out the kinks, or at least the
latest reports point in that direction. The US distributor knows his
stuff, but he can only sell product as good as the factory puts out.
Personal opinion.
your opinions of the Hirth series?
Old August 15th 06, 10:34 PM posted to rec.aviation.homebuilt
Default Hirth
I do not know about all of them but I have had great experience with
a 3203 (fan cooled). The basic concept of nikocil/aluminum jugs is very
sound for air cooled engines. It is how Porsche 911s were made back
when they were aircooled.
As for the 2si, I would take another look at the new ones with the
larger flywheel - ignition trigger spacing. That should have cured
their ignition issues.
Old September 8th 06, 03:27 PM posted to rec.aviation.homebuilt
chuck
Default Hirth
Thank you, I will
your
Old September 10th 06, 05:36 PM posted to rec.aviation.homebuilt
Default Hirth
chuck wrote:
Thank you,
the users.
Personal opinion.
What about Zenoah (Xenoah)?
FF
Old September 17th 06, 11:58 PM posted to rec.aviation.homebuilt
wesley marceaux
Default Hirth
I really don't know anything about the hirth engine ,,never seen one fly
long enough to establish any kind of history . The nickle sil cylinders
works well for a four cycle engine but it has failed badly in the two cycle
except model airplane engines . No matter which engine you choose , one will
always have problems of some sort . Rotax seems to be the engine that gives
the least amount of it.
"J.P." wrote in message
your
Hello, I tought 2si did no longer made engine for aviation
J.P.
Schemp Hirth water ballast dump valves tango4 Soaring 14 September 2nd 04 07:13 PM
Shempp Hirth gear struts. Bill Daniels Soaring 0 August 25th 04 02:10 AM
Hirth F30ES Engine Calvin R. Walker Home Built 1 October 28th 03 05:04 AM
Schempp Hirth or its Representatives... Chris OCallaghan Soaring 11 September 23rd 03 09:28 AM
