WTB Blanik Tow Bridle for L13 or L23
Old August 17th 06, 02:59 AM posted to rec.aviation.soaring
Default WTB Blanik Tow Bridle for L13 or L23
Anyone have one to sell, not being used?
To reply to address, remove "nospam"
Thank you.
Karen
Old August 17th 06, 03:29 AM posted to rec.aviation.soaring
BTIZ
I did not realize the L-23 needed the bridle.. I thought (at least the ones
I've been associated with) L-23s came with a TOST CG hook.
BT
" wrote in message
Thank you.
Karen
Old August 17th 06, 04:10 AM posted to rec.aviation.soaring
Burt Compton - Marfa
Some have it. I have two Blanik L-23's for training and checkrides at
Marfa. One has the side bridal attachments like on the L-13, the other
has the CG hook. Both have nose hooks, of course.
Keep those side bridal release mechanisms clean and lubricated as they
are activated by the same yellow release handle as your nose hook, and
can get a bit sticky. Check them often even if you are not using them.
I use Kroil brand aviation spray lubricant.
Burt
Marfa Gliders, west Texas
USA
Old August 18th 06, 01:45 AM posted to rec.aviation.soaring
BTIZ
Thanx Burt.. I'm only familiar with the newer CAP L-23s.
Bill
"Burt Compton - Marfa" wrote in message
ones
Burt
USA
Blanik L-13 CG Tow Bridle [email protected] Soaring 1 June 11th 06 11:15 PM
Q: Bridle hooks for Blanik L13? Roger Worden Soaring 2 March 4th 06 12:59 AM
Blanik tire problem Greg Arnold Soaring 5 September 30th 05 06:02 PM
Is a Blanik L-33 rugged enough for a club? Val Soaring 0 May 14th 04 02:23 AM
Is a Blanik L-33 rugged enough for a club? jeff rothman Soaring 19 May 13th 04 06:17 AM
