Hey guys I was wondering if any of you could help answer these
questions. What the proper speed to fly is when passing through lift without wanting to stop and work it. When trying to land in rough air should i go faster or slower? What effect will being underweight have on the control of my glider? Where the strongest lift is under a cloud. Is it towards the top? Thanks in advance George |
In article .com,
George writes Hey guys I was wondering if any of you could help answer these questions. What the proper speed to fly is when passing through lift without wanting to stop and work it. You want to go as slowly as possible, to maximize the time you are in lift. When trying to land in rough air should i go faster or slower? Faster. A rule of thumb, set up a speed about a third more than stalling speed, then add half the wind speed. That way if there is a sudden lull in the wind you'll still be able to land without problems. What effect will being underweight have on the control of my glider? If you mean YOU are underweight, the controls will be a bit more sensitive. But I suggest you check weight and balance with your instructor. Where the strongest lift is under a cloud. Is it towards the top? Depends.. As so many things in this mad sport. Generally the lift is easier to work the higher you go. Sometimes the lift is stronger nearer the sunny side of the cloud, sometimes the shady side. Where are you intending to fly, George? Thanks in advance George -- Mike Lindsay |
George wrote: Hey guys I was wondering if any of you could help answer these questions. What the proper speed to fly is when passing through lift without wanting to stop and work it. The technically correct answer can be somewhat complex. Things like MacCready theory and whether you are wanting to optimize speed or glide the furthest given your altitude come into play. In general you want to slow down in lift. No slower than minimum sink. Don't be afraid to pull up hard in strong lift. When trying to land in rough air should i go faster or slower? Faster if you think you might get "gusted", i.e., airspeed might suddenly decrease significantly due to disturbed air currents. What effect will being underweight have on the control of my glider? If underweight means you, the pilot, are below the minimum placarded weight for the glider it could kill you. This is a center-of-gravity (CG) balance issue. Being too light will move the CG aft. A CG that is too far aft can lead to a glider that cannot be controlled safely. A stall/spin is event becomes more likely and may not be recoverable. Where the strongest lift is under a cloud. Is it towards the top? That varies and usually depends on the wind direction and how close you are to the cloud. You may find that *if* there is lift near a cumulous cloud it is towards the upward side. In the US class G airspace you should be no closer than 500', 1000', or 2000', under, over, or to the side of a cloud, respectively. Regards, -Doug p.s. Don't fly a glider unless you have been properly trained. It sounds like you have not received training. Thanks in advance George |
Are you trying to answer test questions, or are you trying to really learn
soaring? Are you trying to sort out the usually conflicting hangar flying questions? In soaring---"It depends--" is the usual correct answer, but it drives beginners and intermediates crazy! This is not an acceptable answer on, for example, the Bronze badge test. The FAA Knowlege test computer has no room for it. That said,--here goes---see below Good luck on your never-ending soaring education - Hartley Falbaum DG800B "KF" USA "George" wrote in message oups.com... Hey guys I was wondering if any of you could help answer these questions. What the proper speed to fly is when passing through lift without wanting to stop and work it. Slow way down. McC theory says the optimum speed can be less than Min Sink under some conditions. The FAA and Bronze Badge says Min Sink. These speeds do not take into account of what happens next. You don't want to be caught going slow in the sink that surrounds the lift, and it is costly of height to accelerate after getting into the sink. So, a practical compromise is about Best L/D, and gentle S-Turn while in the lift. When trying to land in rough air should i go faster or slower? Gusts come from all directions--from behind, they kill your airspeed, and maybe you.-So you want to go fast enough that a "negative" (from the rear) gust won't get you stalled. Speed up --fly Best L/D plus one half the total wind--i.e. wind is 10G15, and L/D is 55 kt, you fly 63Kt (55 + half of 15) What effect will being underweight have on the control of my glider? If you mean "light but legal" the glider will be more pitch sensitive, and performance speeds are reduced slightly. The ratio is the sqrt of the reference weight to the sqrt of the flying weight. If you mean under the legal limit, then you have a big problem, well addressed by the other posters. Where the strongest lift is under a cloud. Is it towards the top? I suspect you mean "under the highest (tallest) part of the cloud"--if so ---yes. The darkest, flattest part of the bottom is a good bet. The upwind edge is a good bet. The sunny side, especially if it is also upwind is a good bet. Some clouds lie through their teeth. Thanks in advance George |
| Thread Tools | |
| Display Modes | |
| US SSA-OLC League new for Summer 2006 Season! | Doug Haluza | Soaring | 20 | April 26th 06 04:54 PM |
| Chicago Soaring Seminar Feb 18th | ContestID67 | Soaring | 0 | December 22nd 05 06:18 PM |
| Introducing NJ's Newest Soaring Club! | Jim Buckridge | Piloting | 2 | February 22nd 05 05:07 PM |
| Possible future legal problems with "SOARING" | Bob Thompson | Soaring | 3 | September 26th 04 12:48 PM |
