Update to IGC-approval for Zander/SDI 941 recorders
Old August 20th 06, 03:23 PM posted to rec.aviation.soaring
Ian Strachan
Default Update to IGC-approval for Zander/SDI 941 recorders
An update to the IGC-approval document for the Zander/SDI 941 recorder
has been agreed and is effective from 20 August 2006. The revised
document will appear on the web site shortly.
The reason for this update is that at the recent World Championships in
Sweden, under poor reception conditions some timing errors were found
in IGC files from type 941 recorders. The reason for these errors is
corrected in Firmware Version V2.11 and the upgrade to 2.11 is
available free to recorders sent to the manufacturers SDI and Zander.
For performances that require evidence of accurate time, where type
941recorders are concerned, only those with Firmware V2.11 or later
should now be used. These points are covered in the amended
IGC-approval document in which the rest of the wording is also updated
to that used in recent approvals.
Ian Strachan
Chairman IGC GFA Committee
Update to IGC-approval for LXN Colibri series of recorders Ian Strachan Soaring 0 February 25th 06 12:03 AM
Update to IGC-approval for LX Navigation LX7000 series of GPS recorders [email protected] Soaring 0 July 20th 05 08:19 PM
Updates to IGC approval documents for GNSS flight recorders Ian Strachan Soaring 2 September 27th 04 01:32 PM
IGC Bureau announcement - Review of World Record procedures and of legacy types of GNSS Recorders Ian Strachan Soaring 0 August 29th 04 07:33 PM
Updated IGC approval documents for Cambridge GNSS flight recorders Ian Strachan Soaring 0 August 27th 03 05:28 PM
