Flight Envelopes
Old August 20th 06, 04:42 PM posted to rec.aviation.aerobatics,rec.aviation.soaring
Michael Nyrup
Default Flight Envelopes
Hi,
I am looking for an Excel sheet or a dedicated program to generate flight
envelopes.
Please let me know if such exsists.
Best regards
Old August 20th 06, 05:56 PM posted to rec.aviation.aerobatics,rec.aviation.soaring
BTIZ
Please define "flight envelopes".
I have a copy of a cross country planner designed in excel.
BT
"Michael Nyrup" aerosign-remove wrote in message
Hi,
envelopes.
Best regards
Old August 20th 06, 09:16 PM posted to rec.aviation.aerobatics,rec.aviation.soaring
Michael Nyrup
With "Flight Envelope" I mean a pictorial way of displaying the strength of
a plane. Load factor on the Y-axis and airspeed on X-axis. Va, Vne, Vd etc.
is plotted and you get a graphical presentation of the plane limitations.
I hope it is a little clearer...
Best regards
MN
Old August 20th 06, 11:58 PM posted to rec.aviation.aerobatics,rec.aviation.soaring
BTIZ
ok... that flight envelope..
I do not have a spreadsheet that would depict that for any given aircraft
given certain input information... but I'm sure someone does
B
of a plane. Load factor on the Y-axis and airspeed on X-axis. Va, Vne, Vd
etc. is plotted and you get a graphical presentation of the plane
limitations.
Best regards
MN
Old August 21st 06, 01:12 PM posted to rec.aviation.aerobatics,rec.aviation.soaring
Here's a "Flight Envelope" one of my buddies is working on:
http://www.personalblimp.com/index.html
See ya, Dave
BTIZ wrote:
Please define "flight envelopes"...
Old August 21st 06, 05:28 PM posted to rec.aviation.aerobatics,rec.aviation.soaring
Michael Nyrup
I haven't made one for a year or two.
It is called a V-n or V-g diagram.
You can make it yourself.
You look up all the information in the POH/AFM.
Horizontal line is airspeed.
Vertical line is g-loading.
Top border is positive-g load limit.
Bottom border is negative-g load limit.
Right border is Vne.
Left border is Zero kts/mph.
The positive knee is at Va, Vs is another point at 1-g.
I would have to go back and review my sources, but this is what I recall
from memory.
I asked Cessna and Piper for the diagrams they generate based on flight
test data, but they would not provide it.
I too have made a few by hand but its never as nice as it would be if
generated by excel or similar.
Old August 24th 06, 11:28 AM posted to rec.aviation.aerobatics,rec.aviation.soaring
Uli
or Vd, if used for design and load calculations
from memory.
and don't forget to consider gust loads. john described the manoevring
envelope which is only part of the flight envelope.
michael: for which purpose do you need the envelope? if you just want to
create a placard for your cockpit, refer to the POH; there you should find
any information needed. if you want to design a new airplane, refer to the
applicable certification specification which describes the flight envelope
pretty well (CS-22 in europe).
uli
Old August 30th 06, 07:59 PM posted to rec.aviation.aerobatics,rec.aviation.soaring
Michael Nyrup
No I am not designing an airplane :-) I just want to have the envelopes with
me and be able to compare them between types. No problem, I can do it by
hand, it's just had been easier (and nicer) to enter the data and have it
plotted automatically.
Regards
Michael
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
Dumb Reg question John Gaquin Piloting 67 May 4th 05 04:54 AM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
