Garmin 496 loss of satellite reception
Old August 21st 06, 12:34 PM posted to rec.aviation.piloting
Dan Luke
Default Garmin 496 loss of satellite reception
Three times in the last two weeks, my 496 has lost satellite reception upon
descent below 2000' AGL.
This occurred in three different locations:
The first time was about a week ago, crossing the western shoreline of
Galveston Bay, just south of Ellington field. Moving the amplified antenna
around the glare shield did not help, so I replaced it with the stub antenna
and reception was restored. I presumed the remote antenna was defective,
and used the stub the rest of the trip.
Saturday, I checked the amplified antenna at startup and it seemed fine, so
I decided to use it and monitor its performance. It had strong reception on
at least 10 sat's until I descended for the visual approach to Slidell, LA.
At 1500' I heard the "Satellite reception lost!" warning and saw that all
the bars were depressed to near nothing. A few came back enough to
reestablish position, and the GPS remained "on line" until landing.
The third time was the trip back from Slidell to drop off the Angel Flight
folks at Fairhope, AL. Same scenario: descended below 2000' and satellite
reception was briefly lost.
I plan another trip this coming weekend just to see how repeatable this
problem is, but right now, I'm mystified. Anyone have an idea what could be
causing this? Pressure effect on the antenna housing, perhaps?
Dan
C172RG at BFM
Old August 21st 06, 09:50 PM posted to rec.aviation.piloting
Dan[_1_]
Dan,
I had ABSOLUTELY the same symptoms with my 396. After much testing, I
narrowed down the failures to when I was close to the ground within
line of site of certain cell-phone towers. (only with the GA25 external
antenna shipped with the unit)
Again, stub antenna worked fine. I contacted Garmin, who sent me
another GA25 antenna (no dice). When I called back, they said that
there have been issues with the GA25 antennas (apparently in the design
iteslf) and sent me a GA26 (the older version, same form factor as the
antenna that came with the GPSMAP 195). So far I believe this will
resolve the issue, but I am planning to test after work today.
Give Garmin a call and ask for a different type of antenna. They'll
even overnight it to you if you tell them you are flying again soon.
--Dan
Dan
C172RG at BFM
Old August 21st 06, 10:26 PM posted to rec.aviation.piloting
Dan Luke
My 396 never did this. It had the antenna in the same place as the new one.
Still, that would be an explanation that fits the symptoms.
Thanks. Will do.
Dan
C172RG at BFM
Old August 21st 06, 11:07 PM posted to rec.aviation.piloting
Dan[_1_]
I figured this out by driving around using the external antenna. You
will find places that ALWAYS lose the signal.
These will generally be very open areas with a cell tower about 1/4
mile away. Put a building between yourself and the tower and the
problem disappears.
--Dan
Thanks. Will do.
Dan
C172RG at BFM
Old August 22nd 06, 05:42 AM posted to rec.aviation.piloting
Dan[_1_]
Followup... The replacement GA26 antenna works perfect...
--Dan
problem disappears.
--Dan
Thanks. Will do.
Dan
C172RG at BFM
Old August 22nd 06, 04:30 PM posted to rec.aviation.piloting
Jonathan Goodish
In article . com,
Ah, perhaps there's the clue. My 396 came with the GA26 antenna, which
is the same antenna that I had with my 195. I noticed that the new 396
and 496 units are shipping with the GA25, which is about half the size
of the GA26. I've never had reception problems with the 195 or 396
using the larger GA26 antenna.
JKG
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Garmin 430 Reception Jon Kraus Owning 16 November 7th 04 03:17 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
