Trip report: flying to Yellowstone in a Grumman Traveler
Old August 22nd 06, 07:26 PM posted to rec.aviation.piloting
M[_1_]
Default Trip report: flying to Yellowstone in a Grumman Traveler
My wife and I just came back from a trip to Yellowstone in our '75
Traveler. See the trip map
http://www.chouby.com/apps/wys.html
We took the southern route through Boise, ID both ways because of the
weather and the limited altitude capability of our plane. Between
Boise and Yellowstone we flew over a vast span of central Idaho desert
with stunning views. West Yellowstone airport is located in a large
half bowl shaped valley with field elevation of 6644 feet. Getting
into WYS we landed in probably 15 knots crosswind, beating a rain
shower by 20 minutes.
Four days later we departed West Yellowstone in early morning with sun
burned faces and sore legs from all the hiking we did at the
Yellowstone National Park. The temperature was just above freezing and
the DA was 6700ft. At 200lb under gross the takeoff from the 8,400
feet runway was quite routine and didn't seem much worse than taking
off from Boise (2800 ft) in a 90F afternoon. The view from the air was
nothing short of spectacular.
Old August 23rd 06, 08:37 AM posted to rec.aviation.piloting
Ok, I am getting confused again,,,, G DA was higher then the field
elevation with the air temp at 32 degrees. Standard day temp is 59f, I
guess you could have had a very"low" pressure system pass through that
mornin.....
Ben
Jackson Hole WY 6430 MSL...
N801BH
Old August 23rd 06, 05:24 PM posted to rec.aviation.piloting
M[_1_]
I didn't actually calcualte the DA using the E6B. I got the DA readout
from the Davtron M655 (http://www.davtron.com/m655.html).
However to answer your qustion, the standard temp of 59F/15C is at sea
level. At higher elevation the standard temperature is lower (I
believe it's close to 2C decrement for each thousand feet in the
standard atmospheric model). So at 6000 feet elevation, the standard
temperature (when the pressure altitude equals density altitude) is
only slighly above freezing.
So in the high countries, if you can walk around in a T-shirt, you
probably need to worry about densitity altitude :-)
mornin.....
Ben
N801BH
Old August 23rd 06, 03:43 PM posted to rec.aviation.piloting
Jay Honeck
Cool trip! Mary and I have planned -- and scrubbed -- several trips to
Yellowstone, due to work schedules and other factors just not coming
together.
We've been through Yellowstone by motorcycle, car, and on foot (in a
very limited way) -- but not yet by air. It's on our "must-do" list,
however.
Thanks for sharing the trip.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 23rd 06, 07:44 PM posted to rec.aviation.piloting
john smith
together.
however.
Ever think about putting a RAP'er trip to Yellowstone together?
Pre/post-OSH?
Old August 23rd 06, 10:56 PM posted to rec.aviation.piloting
Jay Honeck
Pre/post-OSH?
Nope, I hadn't. It would be fun, though.
Not this year, though. My budget still hasn't recovered from OSH!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old August 24th 06, 02:03 AM posted to rec.aviation.piloting
Montblack[_1_]
("john smith" wrote)
Pre/post-OSH?
2,300 statute (road) miles - round trip.
Minneapolis to West Yellowstone ...airport.
http://www.airnav.com/airport/KWYS
KWYS (West) Yellowstone Airport
100 gallons @ 23 miles/gal = $300
+ 10% for extra driving, higher gas prices, etc = $330
No need for motels. g
Mount Rushmore the first night. West Yellowstone the second.
3 RAP'rs (in comfortable captain chairs) - each person drives one hour legs.
We tow a small aerodynamic trailer. Hmm? This idea has legs.
$55/person for fuel - each way.
$8/person for the oil change.
There is no minivan depreciation g
http://www.nps.gov/yell/pphtml/planyourvisit.html
Yellowstone National Park:
Admission: ...Minivan is $25 for 7 Days. That's it.
Camping: .....$15/night in the park. FREE at the airport.
Ok. I'm in.
I just spoke briefly (on the phone) with a guy at Yellowstone Airport. Nice
guy. Much enthusiasm. He said keep him posted if it comes together for next
year.
http://www.yellowstoneaviation.com/
FREE camping on the field - in the trees - 150 ft from your plane. Campsites
have fire pits, showers, bathrooms, picnic tables, the whole nine yards. He
said we'd be pleased with the camping accommodations.
Budget and Avis Rent A Car are on the field.
$4/day tie-down fee.
http://www.yellowstoneaviation.com/flyin.shtml
Flying into WYS info:
Elevation: 6,644 ft
Runway 1/19 ....8400 ft x 150 ft
100LL $4.66 (8/17/06)
Airport is 1 mile north of town
Montblack
Old August 24th 06, 06:09 AM posted to rec.aviation.piloting
Jay Honeck
One hour legs? Sounds like a slow-motion-Chinese-fire-drill... ;-)
Ok. I'm in.
Careful. You might end up being the "party hauler" again! (There
*are* worse fates, I suppose...)
That sounds OUTSTANDING. Better than I expected, by far.
Fantastic. That makes things much easier, unless we all pile into the
airplane of minivans...
Elevation: 6,644 ft
Sounds easy. It's certainly plenty long...
This could be a lot of fun!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old August 24th 06, 08:13 AM posted to rec.aviation.piloting
Grumman-581[_1_]
On 23 Aug 2006 22:09:12 -0700, "Jay Honeck"
Elevation: 6,644 ft
Depends... A few years back, I was departing GCN (9000 ft long, 6609
ft elevation) and wasn't going to be able to clear the trees at the
south end of the runway... It took *forever* to just get into ground
effect and after that, it just wouldn't climb... There was a break in
the trees on the west side of the runway, so I squeezed between them
while still in ground effect... At that point, the ground starts
dropping off a bit and I started catching some thermals... It took
awhile to get the seat cushion unstuck from my butt after that
takeoff... Turns out that after I squeezed through the trees, the
tower issued a warning about a 9000 ft density altitude... That was
when I still had a 150 hp O-320 and as such, the climb performance
with two females and their associated luggage was definitely crap...
Old August 24th 06, 08:17 PM posted to rec.aviation.piloting
Montblack[_1_]
("Jay Honeck" wrote)
legs. We tow a small aerodynamic trailer. Hmm? This idea has legs.
You're focused on the one hour driving blocks. I'm looking at the two hours
blocks, used for stretching out and relaxing ....zzzzz.
Careful. You might end up being the "party hauler" again! (There *are*
First things first, was it a black bear or a grizzly bear - you saw walking
off with my camping gear?
Montblack
Flying into West Yellowstone airport (WYS) M Piloting 19 August 13th 06 11:42 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
Reflections on first trip to Canada from US Mike & Janet Larke Instrument Flight Rules 1 August 9th 03 12:57 AM
