Koch Chart Formula
Old August 23rd 06, 06:40 AM posted to rec.aviation.piloting
abripl[_1_]
Default Koch Chart Formula
Does anybody have the Koch Chart formula (equation)? Or know where to
find it?
I have a chart copy but want the function.
Old August 23rd 06, 09:35 AM posted to rec.aviation.piloting
Peter Duniho
"abripl" wrote in message
find it?
I don't think there is an actual equation that works generally. As an
obvious counter-proof to the idea that there is one, consider that density
altitude affects airplanes with normally aspirated engines differently from
those with turbocharged engines. The same Koch chart would not work for
both types of airplanes.
I haven't done a lot of research on the origin of the Koch chart, but I
believe that it's to be used as a general guideline, not as a precise
determination of how airplane performance is affected by density altitude.
If you do want to implement the Koch chart mathematically somehow, I'd
suggest that your best bet (in terms of ease of implementation) would be to
manually read off a range of pressure altitude and temperature combinations
to create tables giving the performance adjustment, and then interpolate
between the values for specific input of pressure altitude and temperature.
You could more accurately describe a Koch chart mathematically by actually
reverse engineering it (the scales on the middle portion of the chart appear
to be logarithmic and exponential for the takeoff distance and climb rate
reduction, respectively, so you simply need to measure the scales and
determine the base and power for those functions, and the pressure altitude
and temperature graphs appear to be linear), but that may be more trouble
than it's worth. Given that the chart isn't a precise way to determine the
performance change anyway, you may find it's overkill to analyze the chart
that way.
Pete
Old August 23rd 06, 02:10 PM posted to rec.aviation.piloting
Jim Macklin
Google found several "aviation Koch chart" links including
this one
http://wind-drifter.com/technical/technical.htm scroll
down the page. They have some calculators listed, but the
Koch Chart is just the graph. But any high school math
teacher should be able to walk you through the solution of
the algebra problem to find the system of equations.
"Peter Duniho" wrote in
message ...
know where to
| find it?
generally. As an
differently from
would not work for
chart, but I
as a precise
density altitude.
somehow, I'd
then interpolate
and temperature.
of the chart appear
and climb rate
scales and
pressure altitude
be more trouble
to determine the
analyze the chart
| that way.
| Pete
Old August 23rd 06, 05:37 PM posted to rec.aviation.piloting
Peter Duniho
"Jim Macklin" wrote in message
news:CGYGg.5789$SZ3.2892@dukeread04...
this one
down the page.
So what? No one was asking what a Koch chart is, and hopefully everyone
here knows how to use Google by now.
There are no calculators to provide the information that the Koch chart
provides.
Doubtful. There is no single "system of equations" that provides the
general answer that a Koch chart attempts to provide. The best you can do
is to show what the Koch chart itself shows, and that chart is based on
general rules of thumb, not actual mathematically derived functions based on
actual density altitude effects.
Pete
Old August 23rd 06, 06:14 PM posted to rec.aviation.piloting
RST Engineering
I'm sure you can combine equations as well as I, so ...
Variables: D=(density altitude) P=(pressure altitude)
T=(temperature in degrees celsius)
D = (145426 * (1- ((( 288.16 - P * .001981)
/288.16)^5.2563 / ((273.16 + T) / 288.16))^0.235))
APPROXIMATIONS:
For fixed pitch prop, increase sea level standard day takeoff distance 15%
for each 1000 foot increase in density altitude. Approximation good to 8000
feet density altitude
For constant speed prop, replace 15% with 13% in the above equation
For fixed pitch prop, decrease sea level standard day climb rate 7.5% for
For constant speed prop, replace 7.5% with 7% in the above equation.
(Equations and approximations from "Axioms of Flight", James Embree, Flight
Information Publications, St. Louis MO, 1984. ISBN 0-9601062-7-8)
Density altitude equation not independently verified. Use and report
results please.
find it?
Old August 24th 06, 02:44 AM posted to rec.aviation.piloting
Larry Dighera
On Wed, 23 Aug 2006 09:37:50 -0700, "Peter Duniho"
wrote in
provides.
Although not what you were talking about, there is this:
http://www.mountainflying.com/apr_denalt.htm
The APR DENALT (DENsity ALTitude) Performance Computer
To solve the takeoff distance and rate of climb at any particular
density altitude, dial in the outside air temperature (degrees
Fahrenheit) and read the "takeoff factor" and "rate-of-climb
factor" to apply to the normal sea level values obtained from the
Pilot's Operating Handbook.
Old August 24th 06, 05:54 AM posted to rec.aviation.piloting
Jim Macklin
For those who care, you can save the Koch Chart as a picture
file to your computer. Then open it with PAINT or some
other photo editing program. Locate the x,y coordinates for
each part of the graphs and then use those numbers to solve
the algebra problem to get the formula for the system of
equations. Or just use the chart and add a cushion for
safety.
"Larry Dighera" wrote in message
| wrote in
the Koch chart
| provides.
particular
(degrees
"rate-of-climb
obtained from the
Old August 24th 06, 10:08 PM posted to rec.aviation.piloting
abripl[_1_]
I tried a (aT + bP + c)^d type of exponential empirical function
fitting but so far not very exact.
In any case I revised the koch chart into more details with both F and
C temp units and with take off / climb "factors" from SL - easier to
use. Everybody is welcome to the chart at
http://www.abri.com/sq2000/Koch-Chart.gif
My experimental with my engine/prop combo does not have POH values for
takeoff-climb values with altitude and I have flown some over
mountains. Thats why the chart is important to me.
Old August 25th 06, 03:39 AM posted to rec.aviation.piloting
RST Engineering
did you not get the exact equations I posted here two days ago?
ps.com...
Old August 25th 06, 05:00 AM posted to rec.aviation.piloting
abripl[_1_]
Your function was for Da = f(Pa, T) which in turn require various
approximations to get takeoff distance and climb performance - not a
finished product.
I may try again later to get a better empirical function - not
impossible.
Mystery lines on NY VFR terminal chart Ron Garret Piloting 3 May 22nd 05 05:07 AM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
WAC Chart Images on line? Rich Owning 5 March 22nd 04 11:17 PM
King Videos: Jeppesen Chart Review (2 tapes on eBay) Approaches & Enroute, Departures, & Arrivals Cecil E. Chapman Products 0 November 11th 03 05:14 PM
