IFR from CQX (Chatham, MA)
Old August 27th 06, 06:33 PM posted to rec.aviation.ifr
Andrew Gideon
Default IFR from CQX (Chatham, MA)
I see that CQX has a clearance delivery frequency, so IFR ops there
apparently don't require a phone call to FSS (excluding the filing, of
course).
But when IFR out of KCDW, I can expect release delays because CDW
departures are treated with lower priority than TEB, EWR, and probably MMU
departures. What kind of delays would be expected departing from CQX?
I'm trying to decide, assuming the weather permits, if I'd be better at
CQX (more convenient for me) or HYA.
Thanks...
Andrew
http://flyingclub.org/
Old August 29th 06, 04:33 PM posted to rec.aviation.ifr
Denny
IFR flight plan is filed as received.. Your filing will go into the
hopper in order no matter what field you use... What might get you is
the the scheduled carriers are prefiled... SO, your best plan is to
file for the desired IFR departure time EARLY....
denny
Capt Lew Chatham José Herculano Paulo Naval Aviation 1 November 15th 05 02:10 AM
