supercharge TCM IO-550-N
Old August 30th 06, 11:16 PM posted to rec.aviation.owning
kev sep
Default supercharge TCM IO-550-N
Some may find this site use ful when considering engine upgrades
xx
http://www.forcedaeromotive.com/homebuilt.htm
Homebuilt Product Details
The FAT supercharger system is now available for the TCM I0-550-N for
homebuilt aircraft. The lightweight system is located right next to the
firewall for good C.G. and a compact fit. No cowling modifications should be
necessary and no modifications to the propeller shaft are necessary. The
supercharger offers excellent performance gains, and has unsurpassed
durability.
Technical Information:
The supercharger is belt driven off the accessory drive pad next to the
vacuum pump. It will run much cooler than a turbocharger and should result
in much lower maintenance costs. It will add 7-8000 feet of altitude
performance to the I0-550-N. Impeller speed is a function of engine RPM and
therefore over speed and bootstrapping are not considerations. There are no
MP fluctuations while adjusting the throttle, or mixture. Idle cool down
periods are not necessary.
Sea level power to 8500 feet.
77% power to 12, 500 feet, 65% power at 17,500 feet.
Efficient - uses approximately 4.0 horse power at cruise.
Light weight - 27 pounds.
Cool engine temperatures.
Easy pilot workload - no bootstrapping or overshoot.
No TIT to monitor.
No pre-shut down cool down required.
Easy installation - no modifications to exhaust system, fuel system, or
intake system passed the throttle body.
No engine-oil driven control systems.
No scavenge pump.
No waste gate.
Can be removed and the aircraft returned to the normally aspirated
configuration.
Old August 31st 06, 04:47 PM posted to rec.aviation.owning
Matt Barrow
"kev sep" wrote in message
xx
be
durability.
and
no
Gee...my turbonormalized IO-550 get SL power to 20,000 feet.
And it's STC'ed.
Old August 31st 06, 06:16 PM posted to rec.aviation.owning
Frank Stutzman
And it's STC'ed.
And your system is at least $30,000 more expensive.
(Assuming you've got a Tornado Alley turbonormalizer)
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old September 1st 06, 02:43 AM posted to rec.aviation.owning
Matt Barrow
"Frank Stutzman" wrote in message
And it's STC'ed.
Frank Stutzman
Hood River, OR
Yes, it is expensive...and having to cross 14,000 foot mountain ranges to
get anywhere, it damn well worth it. Pretty nice being able to cruise at
12,500 over the flat lands, though, at upwards of 190 kts.
What is the normal rated power of the IO-550 at 12,500, such that this
device is boosting it to 77%?
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO (MTJ)
