Fuel pump cooling shroud?
Old September 4th 06, 11:34 PM posted to rec.aviation.owning
Jim Burns
Default Fuel pump cooling shroud?
Recently we had to replace one of the mechanical fuel pumps on our Aztec due
to a leaking diaphragm.
When talking to several A&P's about the expected life of these pumps and the
cause of failure, most sited heat transfer from the accessory case to the
pump and lack of cooling being the primary culprits. Some A&P's recommended
turning the vac pump outlet to direct air onto the top of the pump, others
said that the fuel flowing through the pump should cool it until you shut
the engine down, then the pump absorbs the engine heat and cooks the rubber
diaphragm.
Not that it would help after engine shut down but I ran across this on ebay
today... http://makeashorterlink.com/?T297322BD Does anybody in the group
have such a shroud on their fuel pump? Aircraft Make/model?
Thanks
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 08:04 PM
Exposed Electrical Wires in Boeing 737 Fuel Tanks! Larry Dighera Piloting 0 July 17th 06 07:13 PM
Lyc IO-360 mech fuel pump suggestion Robert M. Gary Owning 2 February 6th 06 10:49 PM
Christen Fuel Pump troubleshooting ShawnD2112 Aerobatics 4 August 17th 03 01:08 PM
Hot weather and autogas? Rich S. Home Built 33 July 31st 03 12:25 AM
