Flight Sim Jerky Video
Old September 4th 06, 05:49 PM posted to rec.aviation.simulators
Merrill P. L. Worthington
Default Flight Sim Jerky Video
Using MS Flight Simularot 2004.
Just switched LED monitors from a 17" 1024x2048 to a 20" 1050x1400. I'm
using an ASUS A8N-VM CSM with an Athlon 64 3800+ and 2gb PC3200 CAS2
memory. I'm using the on-board video chipset.
When using the "SPOT" view, the panning is now very jerky. I suspect
that the video chipset can't keep up with the panning.
Any suggestions?
Old September 4th 06, 07:00 PM posted to rec.aviation.simulators
Peter Duniho
"Merrill P. L. Worthington" wrote in message
When using the "SPOT" view, the panning is now very jerky. I suspect that
Any suggestions?
Nope. Other than you need to go back and figure out what the actual specs
of your equipment are.
There's no such thing as an "LED" monitor (maybe you meant LCD?), and there
are no LCD monitors that have 1024x2048 resolution (a 2:1 aspect ratio). It
is also customary to list resolutions with width first, whereas you appear
to be listing the height first.
Using a video adapter on the motherboard, you're lucky you can run a flight
simulator in any sort of acceptable fashion at all. If I had to guess, I'd
say that one or the other or both resolutions you state are incorrect, and
that you *actually* went from a lower resolution to a higher one, and that's
resulted in decreased performance, including frame rate stutter.
Pete
Old September 5th 06, 01:07 AM posted to rec.aviation.simulators
Any suggestions?
Pete
Fat fingered the first post.
The native resolution of the first LCD monitor was 1280x1024, the second
is 1400x1050. FS2004 ran OK at that resolution with the motherboard
video chipset (nVidia GeForce 6150) at 1280x1024.
Are you suggesting that the problem should be addressed by a separate
video card with a better chipset?
Old September 5th 06, 02:59 AM posted to rec.aviation.simulators
Peter Duniho
Thank you for the clarification.
Yes, it's possible (though not certain) that a graphic card upgrade will
help or eliminate the problem. You did increase the display resolution on
the video card to match the monitor, I assume, which reduces frame rate and
would cause momentary reductions in frame rate to be more noticeable.
The increase in resolution was slight though, while it sounds from your post
as though the change in performance was more dramatic, so I do wonder if at
the same time the pixel depth was changed as well (for example, from 16 to
32 bits per pixel). Or even some other graphical settings in MSFS (higher
quality, for example).
All that said, there are no guarantees. The rest of the system *seems* fast
enough, but if you have a bottleneck somewhere other than the video adapter
itself, putting a new one in might not help, or might not help enough to
eliminate the problem you're seeing.
IMHO, the first thing to do is go back to the previous resolution you were
doing and make absolutely certain that the problem is tied to the
resolution. But as long as you've determined that for sure, I'd say
upgrading the video would be worth a try (hopefully you have a motherboard
with a PCIx slot, so you can use one of the most recent cards). *Most* of
the time, if a problem is tied directly to the resolution being used, the
video card *is* the bottleneck, and upgrading *will* help.
One could write a whole book on all the various issues that actually exist,
but the above generalizations apply most of the time. This newsgroup is
really beyond the scope of anything more in-depth anyway.
Pete
Old September 5th 06, 05:48 AM posted to rec.aviation.simulators
No changes except for resolution.
Subsequent to the earlier post, I change to a lower resolution and the
jerkiness stopped. When I changed back to the higher resolution, I
noticed the worst problems when clouds were present in the display.
That leads me to believe that there may also be issues with CPU
performance though with a A64-3800+, I'd be a little surprised if I were
CPU bound.
Capiche.
Old September 5th 06, 01:57 PM posted to rec.aviation.simulators
Brett I. Holcomb
Are you running the monitor at it's native resolution? If not that normally
affects the look but maybe it's an issue here.
on the video card to match the monitor, I assume, which reduces frame
rate and would cause momentary reductions in frame rate to be more
noticeable.
post as though the change in performance was more dramatic, so I do
wonder if at the same time the pixel depth was changed as well (for
example, from 16 to
(higher quality, for example).
fast enough, but if you have a bottleneck somewhere other than the video
adapter itself, putting a new one in might not help, or might not help
enough to eliminate the problem you're seeing.
were doing and make absolutely certain that the problem is tied to the
motherboard
of the time, if a problem is tied directly to the resolution being used,
the video card *is* the bottleneck, and upgrading *will* help.
CPU bound.
exist,
Capiche.
Brett I. Holcomb
Remove R777 to email
Old September 24th 06, 06:27 PM posted to rec.aviation.simulators
Any suggestions?
Added a BFG nVidia 7600GT OC. Made all the difference. FS works a lot
better. In addition, overall computer performance as been improved
significantly.
Old October 14th 06, 01:17 AM posted to rec.aviation.simulators
CriticalMass
Hmmm - "Simularot", eh? Yeah, that one's problematic.
CFI without commercial? Jay Honeck Piloting 75 December 8th 10 04:17 PM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Rotorcraft 3 September 27th 06 04:44 PM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
