X11 pirep
Had a chance to try X11 today. First impressions, comparing to
13.4 I normally use: 1. gel pads of X11 are thinner, and they're flattened, and aren't as tight against the head as the 13.4 ones. As a result, passive attenuation of 13.4 is vastly superior to passive X11. 2. weight. X11 is considerably lighter, and it feels much less bulky on the head. 3. sturdiness. X11 is all plastic, and it shows. Of course, that's the price for the light weight. But I don't know what it's gonna look like in five years; it seems a bit flimsy. 4. boom mike of X11 is thinner and more flexible: if in 13.4 you can swing it up just by holding the end of the boom, in X11 you have to hold it by the root of the boom or else it'll just bend up. Also, it is much easier to bend the boom away accidentally, just by touching it lightly -- in 13.4 it usually stays in place. 5. volume control in X11 has no detents, and left regulator is backwards, i.e. ccw rotation is increasing volume. 6. ENC eliminates most of the audible low-freq humming, but adds (or makes audible) some high-freq hissing. 7. battery compartment is way too big: it dangles around too much and gets in the way. Unfortunately, it doesn't have any clip to attach it to anything. 8. I recorded couple of my transmissions using both headsets, and I can't tell the difference: both mikes seem to work the same. 9. in stereo mode, com audio goes to the left ear only. Overall, 1 and 2 make it quite a bit less fatiguing to wear X11 for extended periods of time, compared to 13.4. With ENC on, overall attenuation is better than 13.4, without -- significantly worse. X11 feels more comfortable, except for 4, 7, and 9. Andrey |
X11 pirep
Andrey,
6. ENC eliminates most of the audible low-freq humming, but adds (or makes audible) some high-freq hissing. That hiss is normal for ANR headsets. Read the ANR tutorial at www.anrheadsets.com (Lightspeed) for the reason. 9. in stereo mode, com audio goes to the left ear only. That's normal if you plug a stereo headset into a mono intercom. It's the reason for the switch on the headset. However, music piped into the headset's music input should be stereo regardless of the switch position. If it isn't, the headset is junk. -- Thomas Borchert (EDDH) |
X11 pirep
www.anrheadsets.com (Lightspeed) for the reason. I'll take a look, thanks! It wasn't so much of a complaint; just something I noticed when trying this thing. That's normal if you plug a stereo headset into a mono intercom. It's the reason for the switch on the headset. However, music piped into the OK, I see now. Thanks for explanation. Andrey |
X11 pirep
Good write up Andrey. |
X11 pirep
Thanks for the PIREP Andrey.
-- Jack Allison PP-ASEL-Instrument Airplane "To become a Jedi knight, you must master a single force. To become a private pilot you must strive to master four of them" - Rod Machado (Remove the obvious from address to reply via e-mail) |
X11 pirep
Can someone confirm that the music is stereo regardless of the switch
position? --Dan Thomas Borchert wrote: Andrey, 6. ENC eliminates most of the audible low-freq humming, but adds (or makes audible) some high-freq hissing. That hiss is normal for ANR headsets. Read the ANR tutorial at www.anrheadsets.com (Lightspeed) for the reason. 9. in stereo mode, com audio goes to the left ear only. That's normal if you plug a stereo headset into a mono intercom. It's the reason for the switch on the headset. However, music piped into the headset's music input should be stereo regardless of the switch position. If it isn't, the headset is junk. -- Thomas Borchert (EDDH) |
X11 pirep
Yes, I double-checked, and the switch position indeed has no effect on the
stereo coming from the aux port. I've flown some more with it today, and there are couple of things I'd like to add to my previous pirep. 1. the on/off switch position is not very well-chosen: the switch sticks out a bit, and it is quite easy to move it inadvertently. In particular, it got switched on while being shifted around in the bag. The set ships with its auto-shutoff switch off, but I think I'll start using this feature. 2. got a better feel for the ANR. Weirdly, you seem to hear more noise with it, but it is ...uhmm... less "dense". I'm sure someone with a better grasp on acoustics will be able to explain this, but the feeling I was getting was that there's actually more noise penetrating the ear, but it's kinda flattened, and not as pounding on you. This reduces fatigue quite a bit: I've flown it for just couple of hours, but the difference was apparent. Also, the sidetone seems clearer than I remember it in 13.4. So, now I can add my c2 on the issue of "being able to hear the charts": I was able to hear more noises with ANR on, but they seemed stripped of most of their weight. This did not reduce their clarity, only the amount of "pounding" they produced on the ears. Andrey Dan wrote: Can someone confirm that the music is stereo regardless of the switch position? --Dan Thomas Borchert wrote: Andrey, 6. ENC eliminates most of the audible low-freq humming, but adds (or makes audible) some high-freq hissing. That hiss is normal for ANR headsets. Read the ANR tutorial at www.anrheadsets.com (Lightspeed) for the reason. 9. in stereo mode, com audio goes to the left ear only. That's normal if you plug a stereo headset into a mono intercom. It's the reason for the switch on the headset. However, music piped into the headset's music input should be stereo regardless of the switch position. If it isn't, the headset is junk. -- Thomas Borchert (EDDH) |
X11 pirep
Andrey,
Weirdly, you seem to hear more noise with it, but it is ...uhmm... less "dense". I'm Hmm. This is the part that differs a lot from ANR headset to ANR headset. Your description doesn't do much to convince me of the ANR capabilities of the X11, but I'd like to try it myself. -- Thomas Borchert (EDDH) |
X11 pirep
B,
The ANR sets I've tried seem to "suck out the noise". That's exactly my experience, too. Well, at least the X11 is overpriced and ugly green ;-) -- Thomas Borchert (EDDH) |
X11 pirep
Andrey, make certain to send a copy of your review to DC for potential
improvements. |
Similar Threads | ||||
Prairie Aviation Museum PIREP | Jay Honeck | Piloting | 6 | October 19th 05 09:18 PM |
Approach Plates on PDA (PIREP) | Stan Prevost | Instrument Flight Rules | 10 | December 18th 04 04:21 AM |
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA | Dave Jacobowitz | Piloting | 15 | June 24th 04 12:11 AM |
PIREP question | Andrew Sarangan | Piloting | 6 | January 27th 04 02:21 PM |
PIREP: Headsets Inc conversion of Dave Clark DC10-13.4s | Paul Tomblin | Piloting | 0 | January 20th 04 01:46 PM |
