Q about trailer wheel bearings
Old September 15th 06, 01:13 AM posted to rec.aviation.soaring
Ken Ward
Default Q about trailer wheel bearings
I just pulled off the wheels to replace the tires (cracked side walls),
and I'm wondering about the wheel bearings. I see a grease gun fitting
threaded into a cup, which is captured by a 'C' ring. The grease gun
fitting looks pretty rusty itself.
Should I replace the zerk and pump in new grease, or should I take the
whole cup out, flush out the old grease, put the cup back in with a new
grease gun fitting and start fresh?
Anything else I should look at while I'm in there?
Ken
Old September 15th 06, 02:40 AM posted to rec.aviation.soaring
Mal
"Ken Ward" wrote in message
Ken
I would star fresh and clean the bearings up if the are unsealed !
Make sure you put in a new grease seal and new split pins.
http://www.diynetwork.com/diy/ab_tra...788278,00.html
http://www.off-road.com/chevy/tech/wheel_bearings/
http://autorepair.about.com/cs/doity...h_bearing1.htm
Eberle trailer wheel rims Bob Soaring 7 November 25th 11 05:39 PM
K21 brake parts Stuart Kinnear Soaring 10 June 26th 06 09:54 PM
BGA Tech. News, Wheel brakes. W.J. \(Bill\) Dean \(U.K.\). Soaring 8 May 31st 05 01:55 PM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 03:51 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
