Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aviation Marketplace
intercom + gsm
Old September 15th 06, 12:29 AM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
Magic11
Default intercom + gsm
Hi,
which is the best and not so expensive solution for mobile phone use in
plane!?? Im using David Clark 20-10s headset and looking for something to
connect my mobile phone (2.5mm jack)? it must have feature to give priority
to atc voice when u speak on gsm!!
regards!
Old September 15th 06, 12:37 AM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
Ron Natalie
Magic11 wrote:
Hi,
regards!
Sporty's has just an adapter in their catalog.
Another answer is to switch to something like the Lightspeeds
that have a separate jack for on the control unit that feeds
into a cell phone plug.
Have fun getting GSM to work at altitude.
Old September 15th 06, 12:54 AM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
Robert M. Gary
I'd be surprised if the GSM worked at any altitude above pattern
altitude.
-Robert
Magic11 wrote:
Hi,
regards!
Old September 15th 06, 01:16 AM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
Huck
Hey gang,
It probably wont work in the air of course that being said mine
started ringing at 11,000 ft yesterday above nashville in the t210. I
was amazed of course we were moving so fast that we lost that tower in
seconds but if you have a helicopter it might work. Cell towers all
point down because thats were the people with the electric leashes are!
Sportys does have that adapter but you can probably get the same from
radio shack for nothin. This all being said I HIGHLY RECOMMEND YOU DO
NOT USE YOUR PHONE IN THE AIR!!!!! Not because it is gonna screw with
nav radios or anything but because you will be not concentrating on
what you need to be concentrating on and that is flying the air plane.
Please do not turn into the idiot in his car that is screwing up
traffic because he is on the phone driving. "hang up and drive now
applies to hang up and fly!!!!"
matty
Magic11 wrote:
Hi,
regards!
Old September 15th 06, 09:54 AM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
Thomas Borchert
Huck,
Ah, come one. At FL110 in the 210, you simply aren't busy all the time.
In fact, with the autopilot on, you're way less busy than any time in a
care.
Thomas Borchert (EDDH)
Old September 16th 06, 01:16 AM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
Magic11
"Huck" wrote in message
Hey gang,
I need it for important calls just in case and for passengers, dont worry!
Old September 16th 06, 03:31 AM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
LWG
I read your original post. If you can live with hearing ATC and the cell at
the same time, without priority for ATC, there's a solution for about $15
which I have used very successfully. Get an earpiece for you phone that has
the microphone built into the earbud. These may be a little hard to find
now because the bomm variety is all the rage. Jabra used to make one which
came with different colored earpieces to customize the fit in your ear.
Just slide that under the cup of your headset. The sidetone in your headset
transmits the voice well. I used this setup in Canada where cell phone use
in the air is legal.
Old September 16th 06, 12:19 PM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
Magic11
good idea, tnx!
Old September 17th 06, 11:39 PM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
On Sat, 16 Sep 2006 02:16:14 +0200, "Magic11"
Hey gang,
According to a Lightspeed note, it says the "FCC only allows the use
of a cell phone within the cockpit when the plane is on the ground".
Old September 18th 06, 12:33 AM posted to rec.aviation.marketplace,rec.aviation.misc,rec.aviation.piloting,rec.aviation.products
Newps
It is irrelavant what Lightspeed says.
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill Aviation Marketplace 0 December 11th 03 09:41 PM
FS: Soft Comm ATC-4Y 4 place portable intercom Jaysen Underhill Instrument Flight Rules 0 December 11th 03 09:41 PM
Intercom: IntelliVox vs. ENRI ROBIN FLY Owning 4 December 2nd 03 04:36 PM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Aviation Marketplace 1 October 17th 03 02:04 AM
FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 Jaysen Underhill Aviation Marketplace 0 October 17th 03 01:25 AM
