Approach Timing
Old September 7th 04, 12:50 PM
john smith
Default Approach Timing
For those of you using handheld GPS's when you fly IFR:
Do you use the throttle to increase/decrease power to match the ground
speed to the approach speed table so the time is correct to the MAP?
Or,
Do you use the distance to the airport to determine/verify the MAP, even
though the time may not have expired?
Old September 7th 04, 02:32 PM
Dave S
No
Dave
Or,
Old September 7th 04, 02:59 PM
Newps
A buddy of mine does this. Drives me nuts. He'll sit and screw with
the throttle to get 90 knots ground speed. I want to reach over there
and smack him upside the head. He makes himself so busy trying to fly a
certain groundspeed and he can't see that.
Old September 8th 04, 02:32 AM
Gerald Sylvester
does your friend fly a groundspeed or fly the plane? I know the plane
flies through the air and doesn't know which way the ground goes
(up/down/left/right/forward/backward). If he is doing an
circle-to-land approach say in a 152 with 50 knot tail wind, does
he really have a IAS of 20 knots (or whatever a 152 does an approach
at). If so, his ground speed might be zero knots when he stalls.
Gerald
Old September 8th 04, 03:50 AM
Jerry Kaidor
Newps wrote in message ...
*** Even with a brisk tailwind?
- Jerry Kaidor ( )
Old September 7th 04, 03:19 PM
Mitty
On 9/7/04 6:50 AM, john smith wrote the following:
Or,
Either activity seems unnecessary to this relatively new IA pilot.
Maybe because I already have enough to do on an approach.
Option 1 also sounds like a good way to get dangerously slow if you have
a stiff tailwind.
Doesn't seem like the MAP is that important. So what if you are a bit
early or late when you decide you can't see where you're going? The
result is the same, or should be.
Old September 7th 04, 07:21 PM
Frank Ch. Eigler
Mitty writes:
[...] Doesn't seem like the MAP is that important. So what if you
are a bit early or late when you decide you can't see where you're
going? The result is the same, or should be.
Depending on how big "a bit" is, being late to "go missed" can put one
outside the airspace protected from obstructions.
- FChE
Old September 7th 04, 08:14 PM
Mitty
On 9/7/04 1:21 PM, Frank Ch. Eigler wrote the following:
Mitty writes:
- FChE
Point taken, but you can do rough math within "a bit" in your head I
think. Particularly with a ground speed readout on the GPS. Or
interpolate off the plate.
Old September 7th 04, 03:23 PM
Andrew Sarangan
john smith wrote in news:Cgh%c.81922$cT6.12543
@fe2.columbus.rr.com:
Or,
The MAP time is an indirect way to measure distance. If you can measure
distance directly, why would you still choose the indirect method?
Of course, since the handheld is not an IFR approved device, you will have
to exercise some caution during approaches. What I would recommend is, do
the timing as if you didn't have the GPS, and then verify that it agrees
with the MAP shown on the GPS when the clock winds down to zero.
Old September 7th 04, 04:52 PM
Howard Nelson
"Andrew Sarangan" wrote in message
. 158...
I really, really, really would recommend flying an airspeed under all
circumstances.
Legally your IFR approved clock for timed approaches and NDB for NDB
approaches are what you WILL use. Rationally if my clock or NDB disagreed
with my GPS and I had to make a choice I would trust the GPS.
Along the same GPS train of thought. Try (under VFR with safety pilot)
flying partial panel using "wet" compass and then fly same maneuvers using
the "pseudo" panel on your GPS. Which is easier? Which is more accurate?
I can understand the FAA wanting to avoid a free for all by regulating GPS
usage so carefully. But each pilot, if faced with conflicting data, needs to
decide which technology they trust their life to. The best way to do that is
lots of practice under VFR checking clock vs. GPS, NDB vs. GPS, VOR vs. GPS,
Localizer vs. GPS and make up your own mind.
Also if you are not a renter you might consider spending 15-20K for an IFR
certified GPS linked to your autopilot.
Cheers
Howard
C182P
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.754 / Virus Database: 504 - Release Date: 9/6/2004
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
