Cessna PTT switch normal?
Old September 17th 06, 10:12 PM posted to rec.aviation.owning
Mark Hansen
Default Cessna PTT switch normal?
We have a plane in our club (1978-ish C172N) that has a problem
with the pilot's push to talk switch. It is mounted on the yoke
handle (as if from the factory, not like an after market).
When you press it gently, it works fine. If you press it too hard,
the radio continues to send the carrier, but voice is no longer sent.
Not recognizing what the problem was, after the first complaint from
ATC, I pressed harder on the switch - making the problem occur 100%
of the time. To work around this, I used the built-in hand mike for
the rest of the flight.
It was only after I got back on the ground and began diagnosing the
problem did I remember a notice from the club admin to all members
that this is just how these switches work, and that you must not
press on the switch too hard. Of course, that's just not Human
Nature ;-) If the switch doesn't work when you press it, you press
it harder.
Is this really how "these switches" work, or is the switch defective?
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
Cessna 182T w. G-1000 pirep C J Campbell Instrument Flight Rules 63 July 22nd 04 07:06 PM
Cessna profits plunge......OT (or is it?) C J Campbell Owning 28 February 4th 04 06:13 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
