Flight Plan Equiment Codes?
Old September 19th 06, 04:11 PM posted to rec.aviation.ifr
Mitty
Default Flight Plan Equiment Codes?
A friend just asked me what code to file with his KNS-80 RNAV. I told him that
I thought it was /I but that I usually filed /A with a KNS-80 because I didn't
want ATC to surprise me with an RNAV approach or some kind of weird RNAV
routing. (I don't use a KNS-80 often enough to be really comfortable with it.)
Then we found:
http://www.faa.gov/NTAP/NTAP06AUG31/gen05003.htm
Which is a new chart "Effective September 1, 2005" and it looks like good old
slant alpha is gone and I should now be filing slant uniform in a vanilla
airplane w. just mode c and dme. Is that right? Did the codes change while I
wasn't looking?
Old September 19th 06, 04:17 PM posted to rec.aviation.ifr
Jose[_1_]
Which is a new chart "Effective September 1, 2005" and it looks like good old slant alpha is gone and I should now be filing slant uniform in a vanilla airplane w. just mode c and dme. Is that right? Did the codes change while I wasn't looking?
The codes changed, but /A is still there. In the table, there is a section for NO DME (/X, /T, /U) and a section for DME (/D, /B, /A)
/A is for DME with mode C.
Jose
There are more ways to skin a cat than there are cats.
Old September 19th 06, 04:21 PM posted to rec.aviation.ifr
Steven P. McNicoll[_1_]
"Mitty" wrote in message
that I thought it was /I but that I usually filed /A with a KNS-80 because
I didn't want ATC to surprise me with an RNAV approach or some kind of
weird RNAV routing. (I don't use a KNS-80 often enough to be really
Then we found:
/A is still there, it still means transponder with Mode C and DME. Check
the chart at the bottom of the page, sixth suffix code from the top. /I
would be the proper code for transponder with Mode C and VOR/DME RNAV.
Old September 19th 06, 08:27 PM posted to rec.aviation.ifr
Mitty
Thanks. I was reading the chart wrong. when I saw:
/A Transponder with Mode C
TACAN ONLY
I thought the TACAN ONLY line went with the /A. Now it is obvious that line is
the title for the next subsection.
On 9/19/2006 10:21 AM, Steven P. McNicoll wrote the following:
Then we found:
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
