Hello,
I will built a distributorless ignition. GM coil lmay do the job. http://www.msdignition.com/pdf/8224_frm22622.pdf My question: is the interface block (p/n 8870) is a passive or active one? http://www.shopatron.com/product/pro...=MSD8870/424.0 May I use a faston male terminal for direct connection? Thanks -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
I have one of these coils that I use as a spare when my LSE ignition
coils break. I run it by using the male fast on connectors inserted directly into the base of the coil, no need for the interface block. Rick Pellicciotti Belle Aire Aviation, Inc. http://www.belleaireaviation.com Philippe Vessaire wrote: Hello, I will built a distributorless ignition. GM coil lmay do the job. http://www.msdignition.com/pdf/8224_frm22622.pdf My question: is the interface block (p/n 8870) is a passive or active one? http://www.shopatron.com/product/pro...=MSD8870/424.0 May I use a faston male terminal for direct connection? Thanks -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
Hello, I will built a distributorless ignition. GM coil lmay do the job. http://www.msdignition.com/pdf/8224_frm22622.pdf My question: is the interface block (p/n 8870) is a passive or active one? http://www.shopatron.com/product/pro...=MSD8870/424.0 May I use a faston male terminal for direct connection? Thanks I don't know what kind of salvage yards you have in France, but the coil packs on the Fords,GM's & Chrysler are plenty adequate for AC use--they set the plugs at .050 to .060 inches. Get a set of 2 off of a 4 Cyl. engine--the base is just a mounting point. I built my mag replacement to be gear driven, uses 2 Ford Magnetic pick-up coils, 2 Chevy Ignition modules , and a Ford Double coil. Used electronic units have passed the "Infant Mortality" phase and should give a long useful life. Jerry--could send pics. wassbiplaneattdsdotnet |
jerry wass a écrit :
I will built a distributorless ignition. GM coil lmay do the job. http://www.msdignition.com/pdf/8224_frm22622.pdf My question: is the interface block (p/n 8870) is a passive or active one? http://www.shopatron.com/product/pro...=MSD8870/424.0 May I use a faston male terminal for direct connection? Thanks I don't know what kind of salvage yards you have in France, Nothing with this kind of stuff. but the coil packs on the Fords,GM's & Chrysler are plenty adequate for AC use--they set the plugs at .050 to .060 inches. Get a set of 2 off of a 4 Cyl. engine--the base is just a mounting point. I built my mag replacement to be gear driven, uses 2 Ford Magnetic pick-up coils, 2 Chevy Ignition modules , and a Ford Double coil. I just comme back from the airfield after the 1st run with 2 electronics ignition on my A65... I fly since 3 years with one magneto and one CDI distributorless ignition. You may see (in french) that he http://foxpapa.com/article.php3?id_article=542 I just add two new sensors in the empty magneto, two ignition modules, two new coils (same from Mitsubishi ref MD334558) and it runs. I can start a full 30° advance without any retard system. The wish list for the winter: bolt targets on the flyweel, move the sensors and take apart the empty magneto. I just see the GM coil for price and availability (my coils are order from Australia...), I will try to wire a piggy back second thyristor module in a $120 MAA-6852M Mallory CDI box and drive two $30 SUM-850017 GM coils. The challenge: a CDI distributorless ignition for less than $300 with shipping and import taxes... My A65 become highly modified: a flywhell with starter and kubota alternator (french stuff) http://mdlaurent.free.fr/ one CDI #1 igniton http://foxpapa.com/article.php3?id_article=542 one dual amplifier module (TCI) #2 ignition the module: http://www.transpo.de/cgi-win/product.exe?BM320 an electric wiring similar than the Potez engine one. http://www.jodel.com/index.asp?p=potezwiring&engines By -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
Replacement Cabin Speaker for Cessna? | John Clonts | Owning | 19 | October 12th 05 08:30 PM |
My first in-flight mechanical failure | Peter R. | Piloting | 52 | October 5th 04 09:05 PM |
Coil cord | Hankal | Aviation Marketplace | 0 | October 5th 04 06:18 PM |
Of clocks and learning curves... | Jay Honeck | Owning | 40 | June 16th 04 05:17 AM |
Generating the Juice | terra | Home Built | 24 | September 13th 03 06:30 PM |
