On drag
Old September 24th 06, 10:13 AM posted to rec.aviation.piloting
Default On drag
Is it a fair assumption that at best L/D speed the drag will be the
least?
Thanks in advance,
Ramapriya
Old September 24th 06, 11:48 AM posted to rec.aviation.piloting
Jim Macklin
Default On drag
No, because it is a ratio of lift over drag. You could
reduce lift and also reduce drag.
L/D Ratio Because lift and drag are both aerodynamic forces,
the ratio of lift to drag is ... Aerodynamicists call the
lift to drag ratio the L/D ratio, pronounced "L ...
www.grc.nasa.gov/WWW/K-12/airplane/ldrat.html - 13k -
Cached - Similar pages
aero This phenomenon is called (aerodynamic) ground effect.
.... values could be reached, his X-112 achieved an L/D value
as high as 23 in ground effect flight. ...
http://www.se-technology.com/wig/htm....php?open=aero -
14k - Cached - Similar pages
High-Lift Aerodynamics, Tables of Lift-to-Drag Ratios On
Table 1 we have a summary of aerodynamic efficiency L/D (for
high speed flows, transonic as well as supersonic, the
efficiency is ML/D, ...
www.aerodyn.org/HighLift/ld-tables.html - 6k -
[PDF] Efficient Aerodynamic Shape Optimization File Format:
PDF/Adobe Acrobat - View as HTML
Efficient Aerodynamic Shape Optimization. Antony
Jameson ... Wing L/D. Wing L/D vs. Mach at fixed CL.
Baseline. Redesign. - - - : Baseline. -- : Redesign ...
aero-comlab.stanford.edu/Papers/jameson.iowa.add.2005.pdf
- Similar pages
Aerospaceweb.org | Hypersonic Waveriders - Vehicle
Characteristics Hypersonic vehicle design issues,
configuration, aerodynamic behavior, compression lift ...
Maximum lift-to-drag ratios for hypersonic vehicles and the
"L/D ...
http://www.aerospaceweb.org/design/w...r/design.shtml -
27k - Cached - Similar pages
Aerospaceweb.org | Ask Us - Ground Effect and WIG Vehicles
The aerodynamic efficiency of an aircraft is expressed
through a quantity called the lift-to-drag ratio, or L/D. In
steady, level, non-accelerating flight, ...
http://www.aerospaceweb.org/question...cs/q0130.shtml
- 27k - Cached - Similar pages
Aerodynamics for Students Again assuming approximate steady
conditions where velocity and propulsion performance is kept
constant and that the aerodynamic parameter L/D is
maintained ...
www.aeromech.usyd.edu.au/aero/perf/range/ - 10k -
ps.com...
will be the
| least?
| Thanks in advance,
| Ramapriya
Old September 24th 06, 05:55 PM posted to rec.aviation.piloting
Marc J. Zeitlin
Default On drag
Jim Macklin wrote:
ps.com...
will be the least?
For a given aircraft flying straight and level, lift=weight. Unless
the weight's changing (or you accelerate the aircraft by turning), the
lift doesn't change as you change speed - it still has to equal the
weight to keep the plane in the air.
Given that, then yes - maximizing L/D minimizes drag.
Obviously there are many cases where this won't be true, but for the
most part, it is.
Marc J. Zeitlin
http://www.cozybuilders.org/
Copyright (c) 2006
Aerodynamics of carrying water Gene Whitt Soaring 54 October 19th 05 07:24 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Lower Drag: Rounded or Sharp? Jay Home Built 9 May 10th 04 10:30 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 12:18 AM
