You're invited to download and test SDF - the real time six degrees of
freedom flight simulation software at: http://www.newbyte.co.il/downloads/sdf.zip Fly the simulaton (ficteous UAV) with A/P on or disengaged, explore FCS automodes, try to land it and so on. If you happen to own Microsoft's Flight Simulator 2004 "Century of flight", you can use it as a 3D world slave display on the same computer or on a networked PC. For a post flight briefing, use this graphical utility: http://www.newbyte.co.il/downloads/spl.zip Note: those are Vb6 GUI programs. To save download time, only the second one contains the required VB6 (Service pack6) runtime libraries. C&C are welcomed. __________________________________________ NewByte Aircraft Performance and Flight Dynamics |
Updates (1-Oct-2006, Ver 2.13.1418) :
- Added flight trajectory map. - Corrected turn radius in navigation mode. - Added arresting system. - Corrected flap operation (below 65 knots) bar86 wrote: You're invited to download and test SDF - the real time six degrees of freedom flight simulation software at: http://www.newbyte.co.il/downloads/sdf.zip Fly the simulaton (ficteous UAV) with A/P on or disengaged, explore FCS automodes, try to land it and so on. If you happen to own Microsoft's Flight Simulator 2004 "Century of flight", you can use it as a 3D world slave display on the same computer or on a networked PC. For a post flight briefing, use this graphical utility: http://www.newbyte.co.il/downloads/spl.zip Note: those are Vb6 GUI programs. To save download time, only the second one contains the required VB6 (Service pack6) runtime libraries. C&C are welcomed. __________________________________________ NewByte Aircraft Performance and Flight Dynamics |
Updates (21-Oct-2006, Ver 2.8.1445) : - Corrected landing approach trim calculation. - Added engine dynamics to the linearization model. C&C are welcomed - new forum is open ! Aircraft Performance and Flight Dynamics http://www.newbyte.co.il/ |
Why does the software seek an internet connection?
"bar86" wrote in message oups.com... You're invited to download and test SDF - the real time six degrees of freedom flight simulation software at: http://www.newbyte.co.il/downloads/sdf.zip Fly the simulaton (ficteous UAV) with A/P on or disengaged, explore FCS automodes, try to land it and so on. If you happen to own Microsoft's Flight Simulator 2004 "Century of flight", you can use it as a 3D world slave display on the same computer or on a networked PC. For a post flight briefing, use this graphical utility: http://www.newbyte.co.il/downloads/spl.zip Note: those are Vb6 GUI programs. To save download time, only the second one contains the required VB6 (Service pack6) runtime libraries. C&C are welcomed. __________________________________________ NewByte Aircraft Performance and Flight Dynamics |
I supouse you've pressed the FS button, which tries to find an operationg
Microsoft Flight Simulator on your computer, and if it fails, it looks for it on your local network. That's waht trigerred your firwall warning... Baruch. "Geoff Sjostrom" wrote in message ... Why does the software seek an internet connection? "bar86" wrote in message oups.com... You're invited to download and test SDF - the real time six degrees of freedom flight simulation software at: http://www.newbyte.co.il/downloads/sdf.zip Fly the simulaton (ficteous UAV) with A/P on or disengaged, explore FCS automodes, try to land it and so on. If you happen to own Microsoft's Flight Simulator 2004 "Century of flight", you can use it as a 3D world slave display on the same computer or on a networked PC. For a post flight briefing, use this graphical utility: http://www.newbyte.co.il/downloads/spl.zip Note: those are Vb6 GUI programs. To save download time, only the second one contains the required VB6 (Service pack6) runtime libraries. C&C are welcomed. __________________________________________ NewByte Aircraft Performance and Flight Dynamics |
