Well, I haven't posted here in quite awhile. I'm an IFR-rated PP with
about 400 hours currently. Lately flying about 8 hours a month on average. Had an interesting experience yesterday: a "hard" avionics failure complete with something popping/blowing/burning. Flying a very nice, new (2000) rented 172SP, there was a pop, the audio panel went dead, and then an acrid odor in the cabin. After the couple seconds of stark surprise I flipped the avionics master off. When it appeared there was no real smoke and the smell disappated I tried cycling the master. Nothing bad, but no audio panel (completely dead) and thus no radios. I had just traversed a class C area and was still on with approach when losing the stack. I also happened to be damned near over an uncontrolled field (a generally busy one though approach had called out no traffic and none was visible in the pattern 1000' or so below me). I decided that I should really land there and pulled the throttle out. #1, home field is controlled and I had no radios. #2, since something had definitely 'burned' under that panel, I wanted the airplane on the ground. Of course I couldn't get the WX there with no radios. Airport has a 4/22 and 14/32. Local winds were generally N-NW. After a slow 180 to lose alt I was more or less lined up with 4 and decided that would work. However, on short final I noted that I was crabbing a good 30d and was high as well, though I could have lost the remaining alt with a slip and full flaps easily enough. However, since though I was now NORDO it was not an emergency situation, I decided to do a climing 270 turn into 32, which I did, and was on the ground pretty quickly, all the while looking around everywhere for traffic (none). Taxied to the FBO and grabbed a car back to home airport (45 minute drive - was on local sightseeing flight with a coworker and girlfriend). Overall, in retrospect, I was largely happy with my performance as I didn't panic or anything of that sort (inexcusable) and got the aircraft on the ground pretty quickly. However, I should have done at least one thing differently: I should have either left the avionics master off or, if leaving it on as I did once determining there was no danger, I should have squawked 7600. I never changed my squawk. I elected to leave the panel on mainly to give ATC the benefit of my return, being right on the border of their airspace, and didn't change the squawk because I didn't really think of it. Priority was landing and getting out of the airplane. Oh, I'd also verified the extinguisher on board and had it at the ready. Haven't heard back from the owner yet (local FBO) but I'd imagine a resistor or cap in the audio panel itself went. No breaker had popped (the audio panel doesn't have its own breaker). Lessons learned: 1) ALWAYS have handheld with me. I own one - I'd left it in my own 152, which is what I usually fly. Nothing but laziness in not taking it with me. (What could go wrong on a short, local flight, after all?!) 2) Take a bit of time to think about a squawk in any lost-comm situation. Really, it would have taken 5s to change the squawk and I had plenty of time. Would welcome any comments on the experience. |
Would welcome any comments on the experience. A couple of thoughts: Perhaps call the ATC facility that was last handling your aircraft once on the ground and explain to them what happened? or, use your cell while in the air to call FSS to relay a msg to ATC? -- Peter |
I think you did fine. You had a landing you could walk away from, and the airplane is reusable. ![]() When it appeared there was no real smoke and the smell disappated I tried cycling the master. Nothing bad, but no audio panel (completely dead) and thus no radios. At first I read this as the master, but I think you meant the avionics master. Did any radio lights come on? Did the transponder do its transponder blikey thing? I had an alternator failure once, at night over water coming back from Block Island with a full passenger load (four in all). In retrospect I should have tried cycling the master (I may have actually tried that; I don't remember). My first response was to turn things off to conserve the battery, and to reassure the passengers that the engine would keep running without electricity and we were perfectly fine. I considered what drew the most juice and what gave me the most bang for my buck, and settled on one comm radio, the strobes (which I later turned off), and the transponder. I told ATC (I had flight following) what had happened and what I was doing, they were fine with that. ("are you declaring an emergency?" "no, not at this time"). The front seat passenger startd to feel a little queasy, so I managed to get the air vent pointing right at him, which helped a lot. They asked my intentions, which were to continue on to Danbury, and that I'd be turning the transmitter off. I remember they asked other questions, getting my response via squawking ident on the transponder, then halfway across the Sound I turned the transponder off, figuring they had me on primary, and knew where I was going anyway. It was a clear and a million night, so I flew to Danbury, turned on the radio to contact the tower and landed uneventfully. My friends were very impressed. I guess it doesn't take all that much, but knowing that the engine would keep turning is key. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
A headset will still work, even though the speakers won't.
You'll have to set volume controls. wrote in message ups.com... | Well, I haven't posted here in quite awhile. I'm an IFR-rated PP with | about 400 hours currently. Lately flying about 8 hours a month on | average. | | Had an interesting experience yesterday: a "hard" avionics failure | complete with something popping/blowing/burning. Flying a very nice, | new (2000) rented 172SP, there was a pop, the audio panel went dead, | and then an acrid odor in the cabin. | | After the couple seconds of stark surprise I flipped the avionics | master off. When it appeared there was no real smoke and the smell | disappated I tried cycling the master. Nothing bad, but no audio panel | (completely dead) and thus no radios. | | I had just traversed a class C area and was still on with approach when | losing the stack. I also happened to be damned near over an | uncontrolled field (a generally busy one though approach had called out | no traffic and none was visible in the pattern 1000' or so below me). | I decided that I should really land there and pulled the throttle out. | #1, home field is controlled and I had no radios. #2, since something | had definitely 'burned' under that panel, I wanted the airplane on the | ground. | | Of course I couldn't get the WX there with no radios. Airport has a | 4/22 and 14/32. Local winds were generally N-NW. After a slow 180 to | lose alt I was more or less lined up with 4 and decided that would | work. However, on short final I noted that I was crabbing a good 30d | and was high as well, though I could have lost the remaining alt with a | slip and full flaps easily enough. However, since though I was now | NORDO it was not an emergency situation, I decided to do a climing 270 | turn into 32, which I did, and was on the ground pretty quickly, all | the while looking around everywhere for traffic (none). | | Taxied to the FBO and grabbed a car back to home airport (45 minute | drive - was on local sightseeing flight with a coworker and | girlfriend). | | Overall, in retrospect, I was largely happy with my performance as I | didn't panic or anything of that sort (inexcusable) and got the | aircraft on the ground pretty quickly. However, I should have done at | least one thing differently: I should have either left the avionics | master off or, if leaving it on as I did once determining there was no | danger, I should have squawked 7600. I never changed my squawk. I | elected to leave the panel on mainly to give ATC the benefit of my | return, being right on the border of their airspace, and didn't change | the squawk because I didn't really think of it. Priority was landing | and getting out of the airplane. | | Oh, I'd also verified the extinguisher on board and had it at the | ready. | | Haven't heard back from the owner yet (local FBO) but I'd imagine a | resistor or cap in the audio panel itself went. No breaker had popped | (the audio panel doesn't have its own breaker). | | Lessons learned: | | 1) ALWAYS have handheld with me. I own one - I'd left it in my own | 152, which is what I usually fly. Nothing but laziness in not taking | it with me. (What could go wrong on a short, local flight, after | all?!) | | 2) Take a bit of time to think about a squawk in any lost-comm | situation. Really, it would have taken 5s to change the squawk and I | had plenty of time. | | Would welcome any comments on the experience. | |
Jose wrote:
I had an alternator failure once, at night over water coming back from Block Island with a full passenger load (four in all). In retrospect I should have tried cycling the master (I may have actually tried that; I don't remember). My first response was to turn things off to conserve the battery, and to reassure the passengers that the engine would keep running without electricity and we were perfectly fine. So far, so good. I considered what drew the most juice and what gave me the most bang for my buck, and settled on one comm radio, the strobes (which I later turned off), and the transponder. I told ATC (I had flight following) what had happened and what I was doing, they were fine with that. ("are you declaring an emergency?" "no, not at this time"). Again, so far so good. The front seat passenger startd to feel a little queasy, so I managed to get the air vent pointing right at him, which helped a lot. They asked my intentions, which were to continue on to Danbury Now I'm starting to think there was a bit of get-home-itis going on. I don't know what you were flying, but BID to DXR is the better part of an hour in most spam cans. You were going to overfly a half-dozen towered airports where you could find repair services and rental cars during that time. How did you know you were going to still have enough battery in a half hour to work the radio? Maybe before the alternator went off-line, it hadn't been charging the battery very well for quite a while and you had a lot less battery time than you thought you did. How do you know it was the alternator itself which was at fault, and not some short somewhere which knocked the alternator off-line and was continuing to drain the battery? I know you said it was "clear and a million", but I can tell you from experience that at night, you probably won't know there's a cloud in the sky until you find yourself inside it. DXR has a part-time tower. What if you got there after the tower closed and didn't have any working radio to turn the runway lights on? DXR is surrounded by high terrain. Not the kind of place I'd like to be trying to find a runway in the dark. You've already got a pax who's not feeling well. What were you going to do if "a little queasy" suddenly turned worse and you had no working radio to tell ATC that you needed priority handling at the nearest airport due to an ill passenger? Day-VFR by yourself, an alternator failure should be a complete non-event. At night, it becomes a bit more of an issue. With non-pilot pax (who are YOUR responsibility), I'd be thinking much more conservatively. With one of the pax not feeling well, I'd be thinking getting on the ground at the first reasonable opportunity. |
don't know what you were flying, but BID to DXR is the better part of an hour in most spam cans. You were going to overfly a half-dozen towered airports where you could find repair services and rental cars during that time. That's correct. However, there was nothing critical to repair. The alternator tripped, that's all. The engine's still turning, the weather's severe clear (albeit night), plenty of gas; I saw nothing of any urgency. Even if the battery totally died, I could circle Danbury and get a light gun. If Danbury closed (I think this was before PCL, I don't remember) I could just come in... and if I needed runway lights, I could divert to another airport if necessary. So far, no urgency, but I'm keeping tabs on things. And so is ATC, even if it's just a primary target. You've already got a pax who's not feeling well. What were you going to do if "a little queasy" suddenly turned worse and you had no working radio to tell ATC that you needed priority handling at the nearest airport due to an ill passenger? "little queasy" was not a medical emergency. He was nervous and a little airsick - no more. It went away quickly once he got some cool air on him. (Had it been more, I would have alerted ATC, and if that were no longer possible, I would have simply diverted.) With one of the pax not feeling well, I'd be thinking getting on the ground at the first reasonable opportunity. .... and then what? Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose wrote:
snip "little queasy" was not a medical emergency. Never had a pax throw up on you, huh? |
Not when I was unprepared. ![]() I fly pipers now. I guess I like to live dangerously. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
| Thread Tools | |
| Display Modes | |
| Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 05:40 AM |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| TSA requirement of Security Awareness Training | dancingstar | Piloting | 3 | October 5th 04 03:17 AM |
