Garmin SL30 COMM problem?
Old September 28th 06, 03:03 AM posted to rec.aviation.owning
No Spam
Default Garmin SL30 COMM problem?
I was pulling the avionics boxes to verify serial numbers and now I've got a
problem with my SL30.
At first, it was dead so I re-racked it. That got it to power up, but now I
can't transmit or received on it.
The NAV side works fine, but the data to the external OBS may be screwed up.
What have I done? What can I do?
TIA,
- Kino
Old September 28th 06, 03:27 AM posted to rec.aviation.owning
KP
The radio is not going all the way back in the rack!
TIA,
- Kino
Old September 28th 06, 03:39 AM posted to rec.aviation.owning
No Spam
TIA,
- Kino
It's fully seated.
Anybody got something useful?
- Kino
Old September 28th 06, 05:49 AM posted to rec.aviation.owning
mikem
It's fully seated.
- Kino
Dont be so quick. If the goon who installed the tray in the rack didn't
support both rear corners of the tray, then the tray sags, and when you
engage the jackscrew and use it to pull the radio into the tray, either
the floating BNC or some of the pins in the rear connector get bent. To
all appearances, the radio appears to seat.
I have also seen the rear of the tray get bent by the pressure from the
jackscrew if something doesnt align and a hamfisted person cranks the
jackscrew anyway...
Old September 28th 06, 12:14 PM posted to rec.aviation.owning
Ron Natalie
Pull it out again and look at the connectors. Something
is bent or otherwise not mating properly.
You do know that "pulling things to verify serial numbers"
is not legal owner maintenance (other than under the Ron
Natalie..the wires eventually get to the landing light
sooner or later exclusion).
Old September 28th 06, 04:52 PM posted to rec.aviation.owning
Ron,
Actually, removal and replacement of slide-in, tray mounted avionics (other
than flight control systems, transponders, and DMEs) is specifically
included in the list of allowed owner maintenance items. See FAR Part
43.17(c)(31).
That said, I agree that if the SL30 was working properly just before its
removal the most likely culprit is one or more bent pins on the connector.
Take a close look.
-Elliott Drucker
Old October 4th 06, 07:31 PM posted to rec.aviation.owning
No Spam
On 9/28/06 10:52, "
Ron,
43.17(c)(31).
Take a close look.
-Elliott Drucker
Thanks for the input, everyone.
Turns out, it was the audio panel. Re-racked the unit, after cleaning the
contacts, and everything works. No goons, no loose trays, no violation of
FARs.
Thanks, again...
- Kino
Finding CTAF & PCL freq in a Garmin [email protected] Piloting 3 September 18th 06 12:15 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Garmin 195 screen problem BPattonsoa Home Built 30 December 3rd 03 02:14 AM
