Jim Weir question - Comtronics helmet adaptor?
Old October 2nd 06, 03:33 AM posted to rec.aviation.homebuilt
Cy Galley
Default Jim Weir question - Comtronics helmet adaptor?
I believe Comtronics has a web site. Why not ask the maker?
"Richard Riley" wrote in message
I have a new Comtronics "Ultra Pro 2000" (doncha love that name?)
helmet/headset. It's output is a single 1/4" plug with 3 contact
bands. When I stick it in the phone jack on an intercom I can hear
but (not surprisingly) can't transmit.
I need to make a little adaptor to go from that to a standard 2 plug
output so I can plug into my dull old standard patch cable for an Icom
handheld.
I was thinking you may have already written an article on how to do
that. Got anything lying around, or any advice before I start?
Thanks.
Old October 2nd 06, 05:34 AM posted to rec.aviation.homebuilt
RST Engineering
That's because it ain't $120 worth of jacks and wire. It is $120 worth of
amplifier that takes those few millivolts of microphone audio, uses the bias
voltage coming down the aircraft radio mic audio line, smooths that voltage
into a working voltage for an amplifier, and provides an amplifier that
takes those millivolts to volts to drive the aircraft radio.
On Mon, 02 Oct 2006 02:33:18 GMT, "Cy Galley"
They want $120 for $15 worth of jacks and 3 feet of wire. They're
free to charge that much - but I'm free to try making one on my own.
So I'm going to give it a shot.
Old October 2nd 06, 04:55 PM posted to rec.aviation.homebuilt
Richard
I used to use ex-military headsets and with a little experimentation I
designed an audio amplifier based on the BC108 transistor to do exactly
what RST are suggesting. There were a couple of capacitors and
resistors and a variable pot. The variable pot was the biggest item,
even though I used miniature versions. Unfortunately I am away from
home and I can't remember more, but maybe you have enough info now to
start your project. As I posted in a previous unrelated topic, low cost
replacement cables are available from Headsets Inc at $19
http://www.headsetsinc.com/price_list.htm . The transistor and
components will cost a few cents.
Stan
Richard Riley wrote:
On Sun, 1 Oct 2006 21:34:47 -0700, "RST Engineering"
But I can plug my ordinary David Clark headsets into the dull old Icom
(handheld) standard patch cable and they work fine. Is the
Comtronics mic totally different from the David Clark mic?
Old October 2nd 06, 05:36 PM posted to rec.aviation.homebuilt
Jim Logajan
worth of amplifier that takes those few millivolts of microphone
audio, uses the bias voltage coming down the aircraft radio mic audio
line, smooths that voltage into a working voltage for an amplifier,
and provides an amplifier that takes those millivolts to volts to
I suspect the decimal point needs adjusting - I would have expected a
cost on the order of $12 rather than $120. Jameco carries a number of
educational audio kits that give an idea of the cost of the underlying
hardware needed to perform the task.[1] But unless one is comfortable
with electronics and one has more time than money, presumably the
simplest option is to buy the $120 system.
[1] http://www.jameco.com/webapp/wcs/sto...egoryId=703005
Old October 2nd 06, 07:48 PM posted to rec.aviation.homebuilt
RST Engineering
bias
voltage
No, the microphones themselves are electrically similar. THe difference is
that the Clark headsets have the amplifier cleverly hidden (usually in one
earcup) that takes the millivolts of the actual microphone element and makes
the volts necessary to drive the aircraft radio.
The whole problem is that civilian aircraft microphones have to simulate an
old wheezy carbon element, while military microphones are the raw dynamic or
electret elements without any matching electronics.
Old October 2nd 06, 07:54 PM posted to rec.aviation.homebuilt
RST Engineering
I didn't say anything about the actual parts cost, just the price of the
product. Can you make it for nickels and dimes of parts? You bet. Can you
sell it for $120? Obviously.
Old story about the retired A&P who was called in to see if he could find
the problem with a 747 that nobody else could find. Ten minutes later he
marks a part with an X in chalk and says replace this part and the problem
will be fixed. SUre as hell, they replaced the part and the problem was
fixed. A&P sends the airline a bill for $10,000. The airline objects that
it took ten minutes to find the problem and the bill is excessive and please
itemize. THey got the bill back with $100 for marking the part and $9,900
for knowing where to mark. They paid.
"Jim Logajan" wrote in message
Old October 3rd 06, 02:18 AM posted to rec.aviation.homebuilt
john smith
Old engineering joke, many variations.
Here is another one for you.
Jim, do you know the measure of 1 ORCH?
Old October 3rd 06, 07:50 AM posted to rec.aviation.homebuilt
RST Engineering
I know how to measure in the RCH system, but never heard of an ORCH. A
variation on the theme, no doubt.
Have you ever heard of measuring feminine pulchritude in millihelens?
Old October 3rd 06, 12:46 PM posted to rec.aviation.homebuilt
john smith
Sorry, the O and 1 are redundant.
No, I am not familiar with millhelens.
Old October 3rd 06, 01:33 PM posted to rec.aviation.homebuilt
kd5sak
Default OT- Jim Weir question - Comtronics helmet adaptor?
"john smith" wrote in message
If I've got it "figgered" correctly the original Helen ("Paris Downfall")
would have been rated at
1000 millihelens, Marjorie main would have come in at about 75 millihelens
and Kim Novak at about 1390 millihelens. To bring it into the modern era,
Paris Hilton might rate as high as 395
millihelens. I think I've got the concept straight but we might differ on
the calibration.
Harold
KD5SAK
RT-540A question for jim Weir Billc851 Home Built 1 December 10th 04 09:48 PM
AutoGas question.. Jay Honeck, Jim Weir.. others.. Dave S Owning 32 November 11th 04 10:04 PM
Question for Jim Weir Ed Sullivan Home Built 9 September 21st 04 11:45 AM
Avionic question for Mr. Jim Weir Henning DE Home Built 4 September 19th 04 09:07 AM
Inverter question for Jim Weir B2431 Home Built 35 February 27th 04 09:28 PM
