Hi!
I have a SL30 and a GNS 430 in my plane. They use the same antenna via a splitter. When I dial in the same VOR in both units the SL30 catches up the radials always between 20 and 50 nautical miles earlier than the GNS 430! (Altitude about 3000 ft, flat area) Is this normal? What is your experience? How far away do you have a reception of a VOR with your GNS 430? Fly safe! Maik |
Maik ) wrote:
Is this normal? What is your experience? How far away do you have a reception of a VOR with your GNS 430? I have never noticed a discrepancy between the Garmin's VOR reception and that of my Bendix/King receiver, but I wanted to share a similar problem I had over the summer. When I brought my aircraft in for other avionics work, I ask the shop to verify the installation of the GNS430, which was done by another, rather careless shop for the previous owner of the aircraft. After running a battery of tests, they found that the glideslope receiver in the unit had lost a bit of sensitivity and was below spec. They also discovered that the other shop used a lower grade co-ax cable to connect the antenna, but that is another story. The shop sent the unit to Garmin, who in turn replicated this problem, but had a challenging time correcting it (it had failed Garmin's own internal quality control two times before the problem was fixed). -- Peter |
Maik wrote in message ...
Hi! I have a SL30 and a GNS 430 in my plane. They use the same antenna via a splitter. When I dial in the same VOR in both units the SL30 catches up the radials always between 20 and 50 nautical miles earlier than the GNS 430! (Altitude about 3000 ft, flat area) Is this normal? What is your experience? How far away do you have a reception of a VOR with your GNS 430? *** I have a similar experience. My GNS-430 is clearly less sensitive than NAV2, a KX170B, even though they use the same antenna. I had assumed it was because the '430 has a wideband front end, whereas the KX170B, a much older technology, has a varactor-tuned front end. OTOH, the SL30 should have a wideband front end too. - Jerry Kaidor ( ) |
I remember my avionics tech telling me that it was not recommended to double
up the antenna of a GNS 430 with anotherNAV--especially the older ones. Could be a factor. Marco Leon N36616 FRG "Jerry Kaidor" wrote in message om... Maik wrote in message ... Hi! I have a SL30 and a GNS 430 in my plane. They use the same antenna via a splitter. When I dial in the same VOR in both units the SL30 catches up the radials always between 20 and 50 nautical miles earlier than the GNS 430! (Altitude about 3000 ft, flat area) Is this normal? What is your experience? How far away do you have a reception of a VOR with your GNS 430? *** I have a similar experience. My GNS-430 is clearly less sensitive than NAV2, a KX170B, even though they use the same antenna. I had assumed it was because the '430 has a wideband front end, whereas the KX170B, a much older technology, has a varactor-tuned front end. OTOH, the SL30 should have a wideband front end too. - Jerry Kaidor ( ) |
| Thread Tools | |
| Display Modes | |
| Garmin Specials ADV | Michael Coates | Home Built | 0 | March 18th 04 01:24 AM |
| Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 06:29 PM |
| Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 03:04 AM |
| "Stand Alone" Boxes (Garmin 430) - Sole means of navigation - legal? | Richard | Instrument Flight Rules | 20 | September 30th 03 03:13 PM |
| Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 10:04 PM |
