GNS430 Restore Defaults?
Old October 5th 06, 07:36 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
Default GNS430 Restore Defaults?
My new airplane has dual GNS430s, and I would like to start out with a clean
slate on them.
Is there a way to reset the entire unit to factory defaults, clearing all
flight plans and user waypoints at the same time?
Stan
Old October 5th 06, 08:36 PM posted to rec.aviation.ifr
karl gruber[_1_]
I'd be careful. There are settings in there of communicating with you GPS,
Fuel Flow, and transponder.
Karl
"Stan Prevost" wrote in message
clean slate on them.
Stan
Old October 5th 06, 09:00 PM posted to rec.aviation.ifr
Frank Stutzman
slate on them.
First of all, listen to what Karl said in the previous post. Mucking around in this fashion
may not be what you want to do. But to answer the question...
If I remember correctly, Press and hold the 'clear' button while turning the unit on.
Pressing and holding 'enter' button while powering on gets you to the hardware setup pages that
allows you to change all sorts things that Garmin, your avionics shop and your wallet wished
you didn't touch.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old October 5th 06, 09:34 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
Well, the unit is the GPS. Maybe you mean the other GPS. But the other
interfaces would be of concern, I didn't think about them. What I would
like is to just reset the user-settable things not on the maintenance pages.
If it is all or nothing, then I will do it the long way.
Stan
"karl gruber" wrote in message
Karl
Stan
Old October 5th 06, 11:20 PM posted to rec.aviation.ifr
Mitty
When we put a 430 stack in one of our club planes I talked to Garmin about this.
1) There is no way to reset only the user screen-type options.
2) There is a way to reset the entire box at power up (probably the method
suggested in another post), but this also resets a bunch of GPS position
information that takes about 15 minutes to rebuild the next time the box is
turned on. (I may not have the time exactly right, but it was unacceptably long
for our purposes. It may be o.k. for your needs though.)
3) The Garmin support guy that I was communicating with (a year ago) put a
suggestion into the software developers' queue that they come up with a simple
user-interface-defaults-reset in some future version of the software. He agreed
that it would be a very good safety thing for any airplane flown by more than
one pilot.
I got all this by emailing Garmin support. I'd suggest you try them rather than
relying solely on newsgroup inputs.
On 10/5/2006 12:36 PM, Stan Prevost wrote the following:
slate on them.
Stan
Old October 6th 06, 04:59 AM posted to rec.aviation.ifr
skym
slate on them.
Stan
Isn't there a "restore defaults" option on one of the pages? I don't
have my manual handy, but IIRC it seems like there is one on one of the
pages.
Old October 6th 06, 05:33 AM posted to rec.aviation.ifr
Stan Prevost[_1_]
Yes, most pages have restore defaults, but it applies only to the local
parameters. Apparently there is no means to just reset user parameters
without also messing up the installation and configuration options.
"skym" wrote in message
clean
slate on them.
Stan
pages.
Garmin GNS430 upgrade "schedule" Andrew Gideon Products 7 October 7th 04 12:06 AM
GNS430 Installation Wayne Sweet Home Built 0 October 3rd 04 05:39 AM
B-RNAV with GNS430 Daniel Hofer Instrument Flight Rules 1 September 1st 04 05:12 PM
Wanted: Blank Datacard Garmin GNS430 Marco Leon Piloting 4 August 31st 04 07:20 PM
Vietnam Veterans Working To Restore Helicopter Used In War Otis Willie Military Aviation 0 May 26th 04 11:36 PM
