plate question
Old October 6th 06, 09:02 PM posted to rec.aviation.ifr
Andrey Serbinenko
Default plate question
After looking at the ILS-Z approach in NC that was discussed here some time
ago, I was curious how many similar approaches there are, and if they all
are military. Thanks to the uniform naming NACO uses for its chart files,
it was fairly easy to get a list of all the ILS-Z approaches: there aren't
that many, probably a dozen, and all of them are military -- usually there
would be two -- a Z GPS approach, and a Y RNAV counterpart.
But for one place:
http://www.naco.faa.gov/d-tpp/0610/00641IY12.PDF
There's only ILS-Y approach here, and no Z approach. Does anyone know
why there's no Z?
Andrey
Old October 6th 06, 09:07 PM posted to rec.aviation.ifr
Jose[_1_]
why there's no Z?
Just a guess... maybe there was one and it was decomissioned. Changing
the names around would invite disaster (though that doesn't stop them
from changing taxiways areound)
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old October 6th 06, 09:23 PM posted to rec.aviation.ifr
Bob Gardner
This comes from the TERPs, and applies to all approaches, not only military
approaches:
"Where more than one approach using the same final approach guidance is
developed to the same runway, identify each for the runway/navigational aid
combination with alphabetical suffix beginning at the end of the alphabet;
e.g., ILS Z RWY 28L (first procedure), ILS Y RWY 28L (second procedure), ILS
X RWY 28L (third procedure), etc."
Bob Gardner
"Andrey Serbinenko" wrote in message
time
But for one place:
why there's no Z?
Andrey
Old October 7th 06, 12:49 AM posted to rec.aviation.ifr
Brad[_1_]
But for one place:
why there's no Z?
Andrey
There is, but it looks like its a "special", meaning it is not a public
procedure...see link below
http://avn.faa.gov/acifp.asp?search=...bmit1= Search
Old October 9th 06, 09:02 PM posted to rec.aviation.ifr
Andrey Serbinenko
Interesting... it looks like they had two preliminary drafts for the ILS,
and the combination of them has become the published "Y" procedure
(it has vertical profile of the "Z" draft, and missed approach of the "Y"
draft, 19-dme arc of the "Z" draft, and minimums of the "Y" draft).
Thanks for the link!
Engine Data Plate Micha³ Cebrowski Owning 3 April 12th 06 08:01 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Phoenix AIM-54A (QUESTION) Krztalizer Naval Aviation 10 February 23rd 04 07:22 AM
FS: 1984 "The Nonsuch" (Sailing Vessel) Lim Ed Collector Plate in Ontario J.R. Sinclair Aviation Marketplace 0 February 15th 04 05:57 AM
