Testing spray pattern on turbine injectors
Old October 11th 06, 07:06 PM posted to rec.aviation.homebuilt,rec.aviation.misc
Juan Jimenez[_1_]
Default Testing spray pattern on turbine injectors
I'm in the middle of cleaning the injectors of the engine on my BD-5J, and I
was wondering if someone here has dealt with this issue before...
I need to test spray pattern. The engine has 8 injectors. I know I can set
up a rig where I pump fuel into the injectors, and perhaps use a piece of
cardboard 12 inches from the injectors to see what the spray pattern looks
like after a shot of fuel. I would be looking for uniformity of pattern from
all injectors.
Am I missing something else I should look for?
Juan
Posted via a free Usenet account from http://www.teranews.com
Old October 12th 06, 01:34 AM posted to rec.aviation.homebuilt
paul
On Wed, 11 Oct 2006 14:06:13 -0400, "Juan Jimenez"
all injectors.
Juan
Years ago while in the USAF as a jet engine mechanic we used a stand
where the nozzles were screwed into a fixture vertical with a clear
Plexiglas panel over the nozzles approximately 6" which allowed us to
inspect the spray pattern, if one was off we immersed the injector in
a de carbon mixture and retried the pattern. One thing that you should
remember is the injector tips are fragile, if you must attempt to
remove any hard deposits use a orange stick or a tampico brush. Good
luck, please remember this is how it was done in the 60's perhaps a
newer and better method has been devised
Old October 12th 06, 02:29 AM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
"paul" wrote in message
news
I
from
all injectors.
Juan
Believe it or not, another BD-5J owner uses this EXACT same method. Deja vu.
Testing spray pattern on turbine injectors Juan Jimenez General Aviation 2 October 25th 06 03:30 AM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
